undefined reference to `__exidx_start' when starting new system,
OP #2993940
• ▲ useful
▼ not useful
Hello, hope someone can give me a hint?
I have built a new system, now with Win7. I also upgraded to gcc 4.7.2.
When linking I get errors I never seen before:
make all
..linking
arm-none-eabi-ld -v -Map main.map -Tlinkconfig_FLASH.cmd -o main.out
crt.o  main.o timerisr.o timersetup.o isrsupport.o lowlevelinit.o
TWI_ctrl.o display.o HandleDDS.o menu.o buttons.o SPI_ctrl.o
eepromhandler.o a2dmodule.o Smeter.o commands.o  cdc_enumerate.o
serialARM.o  -L"C:/yagarto/lib/gcc/arm-none-eabi/4.7.2/"
-L"C:/yagarto/arm-none-eabi/lib/" -lc -lgcc
GNU ld (GNU Binutils) 2.23.1
C:/yagarto/lib/gcc/arm-none-eabi/4.7.2/\libgcc.a(unwind-arm.o): In
function `get_eit_entry':
C:\msys\1.0\home\yagarto\gcc-build\arm-none-eabi\libgcc/../../../gcc-4.7
.2/libgcc/unwind-arm-common.inc:221:  undefined reference to
`__exidx_start'
`__exidx_end'
function `unwind_phase2':
.2/libgcc/unwind-arm-common.inc:289:  undefined reference to `abort'
function `__gnu_Unwind_Resume':
.2/libgcc/unwind-arm-common.inc:487:  undefined reference to `abort'
.2/libgcc/unwind-arm-common.inc:505:  undefined reference to `abort'
C:/yagarto/lib/gcc/arm-none-eabi/4.7.2/\libgcc.a(pr-support.o): In
function `_Unwind_GetDataRelBase':
.2/libgcc/config/arm/pr-support.c:394:  undefined reference to `abort'
function `_Unwind_GetTextRelBase':
.2/libgcc/config/arm/pr-support.c:400:  undefined reference to `abort'
make: *** [main.out] Error 1
And I do not understand where "msys\1.0\home" in C:\msys\1.0\home\ etc
come from...
I really would appreciate some hints...
Nils
Moderator #2993963
• ▲ useful
▼ not useful
Answered by Ian Lance Taylor:
http://gcc.gnu.org/ml/gcc-help/2009-10/msg00335.html
"These and the other undefined symbols are intended to be defined by
the linker script."
For example:
    .bss (NOLOAD) : {
        . = ALIGN(4);
        _szero = .;
        *(.bss)
        *(COMMON)
        . = ALIGN(4);
        _ezero = .;
    } >sram
    __exidx_start = .;
    .ARM.exidx   : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) } >sram
    __exidx_end = .;
The function abort() is something you have to provide yourself.  Do
whatever seems to be most useful in case of a software-triggered
abort: flash some LEDs, beep a buzzer, whatever you've got.  The
most minimal abort function is certainly:
void abort(void)
  for (;;) { }
OP #2994109
• ▲ useful
▼ not useful
a small update!
I found out that the binary was 2MB+ big, a "tiny" bit too big for my
flash (256KB)
So I made a small mod to your suggestion, Ian!
This is your version:
    __exidx_start = .;
    __exidx_end = .;
And after intensive study in another forum my version:
  .ARM.exidx : {
    __exidx_start = .;
    __exidx_end = .;
  } >flash
  _etext = .;  /* define a global symbol _etext just after the last code
byte */
So now the binary is 94kB, more handy for the flash.
Don't ask ME why they give such different result!
Hope it will help somebody???
Nils
Moderator #2994137
• ▲ useful
▼ not useful
Well, I am not Ian. ;-)  Ian Lance Taylor is a long-term opensource
contributor.
>     __exidx_start = .;
>     __exidx_end = .;
>   .ARM.exidx : {
>     __exidx_start = .;
>     __exidx_end = .;
>   } >flash
It would be interesting what did cause your bloat.  But thanks for
the feedback, I'll keep it in mind for my own stuff, too.
OP #2994203
• ▲ useful
▼ not useful
I am so sorry, Jörg!
Misunderstanding, me not reading the full answer! Sorry!
I missed:
>the linker script."
I will try to go back to the bloating version and look in the .map file,
if possible. And get back to you with result.
Now time for BBC-news!
Bis morgen!
Nils
OP #2994952
• ▲ useful
▼ not useful
Hi Jörg (NOT Ian!!!)
Mapfiles show the sram pointer is at fault!
Bloating:
   __exidx_start = .;
    __exidx_end = .;
  _etext = .;  /* define a global symbol _etext just after the last code byte */
Unbloating:
  .ARM.exidx : {
    __exidx_start = .;
    __exidx_end = .;
  } >flash
So my QROlleII is now running nicely w/ new SW!
73 de Nils
(Moderator: deleted attachment to this post, see below)
OP #2994961
• ▲ useful
▼ not useful
Sorry, I have been bloating the forum: sent the bin file instead of the
map files!!!
Bloating:
   __exidx_start = .;
    __exidx_end = .;
byte */
Unbloating:
  .ARM.exidx : {
    __exidx_start = .;
    __exidx_end = .;
  } >flash
last code byte */
73 de Nils
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
