Forum: ARM programming with GCC/GNU tools Please help in solving the warning "cast increases required alignment of target type"
von Karthik C. (karthik_c)
I have two structures as below
Code:
struct prefix
   u_char a;
   u_char b;
   u_char c;
   u_char d;
   u_char e[4];
struct in_addr
   union{
     u_int8_t addr8[16];
     u_int16_t addr16[8];
     u_int32_t addr32[4];
   } in6;
When I used the above structures as a function argument as below
log(.......,(struct in_addr*)p->addr32,......); // where p is a pointer
to structure prefix
/* log function accepts variable arguments and the argument "struct
in_addr*)p->addr32" is one of such variable arguments. */
at that point, I am getting the warning as "cast increases required
alignment of target type".
Googled for solution but very confused among "_attribute_ ((packed));"
and "_attribute_ ((alligned) (x)) ;", which one to use and why?
Please help me
von kbuchegg (Guest)
There seems to be something seriously wrong
You tell the compiler
that is:
  take p    (whcih is a pointer to a prefix object)
  use it, as if it were a pointer to an in_addr
  and fetch the addr32 member.
Now.
If p is in reality a pointer to an prefix object, it points to an
object, which looks like this
struct prefix
   u_char a;
   u_char b;
   u_char c;
   u_char d;
   u_char e[4];
what is the size of such an object, how big is it?
Well, guesses are, that it has a size of 8. a, b, c, d account for 4
bytes, plus the 4 bytes for e makes 8.
(But better check that! It may be, that the compiler inserted some
padding bytes!)
So p points to something that uses 8 Bytes in memory.
Now you tell the compiler to assume, that that something in memory is an
in_addr, which looks like this
struct in_addr
   union{
     u_int8_t addr8[16];
   } in6;
How big is that?
Let us just concentrate on the addr32 member. It is an array of 4
elements, each one beeing an u_int32_t. Well u_int32_t is not a standard
C Datatype, but guesses are that the notation means: unsigned int with
32 bits.
Well an 32 bit integer type means 4 bytes. And since there are 4 of
them, that means the whole addr32 member has a size of at least 16
bytes.
But that doesn't fit!
p points to something that has a size of 8 bytes and you want to trick
the compiler into believing that in reality it has 16 bytes.
Hmmm.
If you ask me, there seems to be something seriously wrong.
von Markus F. (mfro)
> Hmmm.
That's a pretty nice explanation, but unfortunately it's not the reason
for the warning the thread starter experienced. The problem described
might be an issue, but it's not the cause of the warning.
It's perfectly legal in C to dereference any pointer to an object of
small size through a cast pointer to a larger object type. Usually,
there is no warning issued, the compiler just takes the pointer,
dereferences it and accesses the memory "behind" the original object
regardless if it's meaningful or not.
The reason for the warning "cast increases required alignment of target
type" is caused by the platform architecture requiring 32 bit variables
to reside on even (or even "doubly even") addresses. The first struct
can live at any odd or even address, the second one has limitiations.
Accessing the first structure cast to the type of the second could cause
a misalignment exception (or whatever the platform does when accessing
data through misaligned pointers).
If you want to get rid of the warning (and runtime errors that possibly
result from the potential misalignment),  you'll need to adjust the
alignment requirements of the first struct identical to those of the
second.
You could do that by appending
__attribute__ ((aligned (4)))
 to the structure definition (gcc-specific, not portable) or by nesting
the structure into a union with another element (which you don't need to
use, it just must be there) that has the same alignment requirements
than the other structure - this would be portable.
