Forum: ARM programming with GCC/GNU tools what does (size before relaxing) in a GCC .map file mean and how does it work?
Author: (size before relaxing) GCC (Guest)
Hello,
Please help me understand how the compiler does the flowing
optimization:
I have an array of strings (pointers to char) declared this way:
const char* const STR_ARRAY[] =
"first",
"second",
"third",
"fourth",
"fifth",
... and so on ..
"last"
After compiling, I fond in the .map file the memory zone where the
string where saved and I was surprised to see that some optimization was
made.
.rodata.str1.1
                0x01055586     0x1af3 .myStrArray.o
                               0x2060 (size before relaxing)
The actual size of my strings is 0x2061 (all the letters + the null
terminator for each string), but only 0x1af3 bytes used..
Thank you,
Andrew
Author: A. K. (prx)
Are there duplicate strings, or strings where one is identical to the
ending of another?
Thank you for the reply A.K.,
There are no duplicate strings, but indeed there are strings where one
is identical to the ending of another (like: "first" and "the first").
More there are situations where the beginning of one sting is identical
to another string (like: "first" and "first string") or the beginnings
of two strings are identical (like: "the first" and "the second").
Is this how the optimization is made?
Thanks again,
Andrew
Author: A. K. (prx)
It was just a guess, but I do know that compilers such as GCC are able
to share identical strings. If some string is idential to the trailing
part of another, it can be omitted entirely as the corresponding part of
the longer one can be used instead. It won't work with shared prefixes
though, since they miss the \0 in the proper place.
Author: A. K. (prx)
Since both sizes are shown in the map file, it likely is caused by some
optimization done by the linker though.
I spent some time analyzing the memory and I observed that you were
right.
For two strings, when one is identical to the ending of the other, for
example "first\0" and "the first\0" only the longer string, in this case
"the first" is stored in memory.
I have not investigated if the optimization is made by the linker or the
compiler.
Thanks,
Andrei
Author: Johann L. (gjlayde)
It's calles string merging.  The trigger is the right sections flags set
by the compiler, which then are avaluated by the linker in order to
merge the strings.  Look at the generated assembler code.  GCC puts the
strings into sections with flags like "aMS".  "M" allows merging and "S"
marks it as a section containing strings.
Author: pooter (Guest)
the size after relaxing should be always smaller than before
No, not necessarily.  It can be the same size.  And depending on what
relaxations are performed, code sie can even increase.
An example for increasing code size is when a jump / call is out of
reach and a jump pad just after the function is added that forwards to
the the  jump target, and the original jump jumps to the pad.
