Forum: ARM programming with GCC/GNU tools Yagarto: Cortex-m3 linked ok, Cortex-m0 not
von Kreyl L. (kreyl_l)
I have a lot of projects with stm32f1xx CPUs (cortex-m3), all is good
with them.
Now I decided to make project with stm32f051 (cortex-mo), and linker
works with errors.
I have several cpp files (task is to light-up LED), they are compiled
with no errors when any of cortex-m3 or cortex-m0 is set as mcpu.
But linker works ok with mcpu=cortex-m3 option, and with errors with
mcpu=cortex-m0. But still linker says that job is done.
I use Yagarto with GCC v.4.7.2.
Here is output:
arm-none-eabi-g++ -T"D:\Nute\_tmp_\f0test\STM32F051R8.ld" -Xlinker
--gc-sections -Wl,-Map,f0test.map -mcpu=cortex-m0 -mthumb -o
"f0test.elf"  ./src/main.o  ./lib/src/stm32f0xx_rcc.o
./lib/startup_stm32f0xx.o ./lib/system_stm32f0xx.o  ./kl_lib/kl_lib_f0.o
c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/
bin/ld.exe:  error:
lib/crt0.o:  Conflicting CPU architectures 11/1
bin/ld.exe:  error: ./lib/src/stm32f0xx_rcc.o: Unknown CPU architecture
bin/ld.exe:  error: ./lib/system_stm32f0xx.o: Unknown CPU architecture
bin/ld.exe:  error:
c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.7.2/thumb/v6m\libgcc.a(_udivsi
3.o):  Unknown CPU architecture
bin/ld.exe:  error:
lib/thumb/v6m\libc.a(lib_a-atexit.o):  Unknown CPU architecture
bin/ld.exe:  error:
lib/thumb/v6m\libc.a(lib_a-fini.o):  Unknown CPU architecture
bin/ld.exe:  error:
lib/thumb/v6m\libc.a(lib_a-init.o):  Unknown CPU architecture
Finished building target: f0test.elf
bin/ld.exe:  error:
lib/thumb/v6m\libc.a(lib_a-__atexit.o):  Unknown CPU architecture
bin/ld.exe:  error:
c:/yagarto/bin/../lib/gcc/arm-none-eabi/4.7.2/thumb/v6m/crtend.o:
Invoking: ARM Yagarto Windows GNU Create Flash Image
arm-none-eabi-objcopy -O ihex f0test.elf  "f0test.hex"
Finished building: f0test.hex
When I use option -nostartfiles, obviously I have an error that _init()
is not found.
What is wrong with cortex-m0? Cortex-m3 is ok with same options.
Thanks in advance!
von hp-freund (Guest)
Hmm, and what can I do with these letters 3 years old? Was those patch
not included in GCC v.4.7.2?
von Martin Thomas (Guest)
You may try to replace -mcpu=cortex-m0 with -march=armv6-m and rebuild.
Maybe it's just a small issue with the multilib-setting/cores-defintions
in Yagarto but MiFi can tell more about the configuration.
The prebuild toolchains from https://launchpad.net/gcc-arm-embedded,
http://sourceforge.net/projects/devkitpro/files/devkitARM/ or
http://www.mentor.com/embedded-software/sourcery-tools/sourcery-codebench/editions/lite-edition/
may also be worth a try. All of them are arm-none-eabi toolchains
created from gcc/binutils/newlib sources very similar to Yagarto.
Thank you, Martin, I will try tools you mentioned.
Actually, I solved the issue by adding -nostartfiles to linker options
and implementing empty _init() function.
von prasad (Guest)
I am trying to build arm compiler tool chain for cortex a9 processor for
freescale on redhat platform.. can any one suggest me the compatible
versions of gcc lib, gcc, gnuutil along with kernel header files..
Please open another thread if your question is not related to the
original post. Anyway: the question implies that you are looking for an
arm-linux cross-compiler. Information, Code and Binaries available from
http://www.linaro.org/ should be a good starting-point.
