Forum: ARM programming with GCC/GNU tools Problems with Code sourcery G++ , audio playback file
Author: (unknown) (Guest)
Dear All,
            Greetings !!!
I am trying to build a code example given with the STM32F4 discovery
board and am getting the following problems in the console/ after build
ct/Audio_playback_and_record/inc/usb_conf.h:139:6:  error: #error
"USB_OTG_HS_CORE or USB_OTG_FS_CORE should be defined"
t/Audio_playback_and_record/inc/usb_conf.h:152:6:  error: #error
"USE_USB_OTG_HS or USE_USB_OTG_FS should be defined"
cs-make: *** [temp_folder/usb_bsp.o] Error 1"
I could find one reference to this problem in one of german version of
this forum but could not understand the solution well(if it at all it
was suggested). So can somebody throw some light on this issue?
Tools: Eclipse Indigo
Compiler: Code sourcery G++ Lite
Debugger: Atollic gdb server
Linker, STLink.
Board: STM32F4 Discovery
Toolchain status: I have been able to download and debug a simple LED
blinking project in this toolchain so I have some idea about what all
files to include , etc.
One more question:
Although unrelated but, since the Atollic toolchain has a code
limitation of 32k, would I face a similar problem if I use their
debugger? I havent reached that far so dont have an idea about the same.
Arm user wrote:
> error: #error "USB_OTG_HS_CORE or USB_OTG_FS_CORE should be defined"
Since nobody else anwered so far just a quick hint from someone who has
not done that much with STM32 und USB: as written in the error-message
one of these symbols (better: preprocessor macros) needs to be defined.
Usually the definition is done by a parameter to the compiler (indirect
to the preprocessor).
IRC the ST-Micro examples come with project-settings for uVision, EWARM
and Truestudio. Most of these files a human-readable, open them in an
editor and search for one of Names. Pass this name using the gcc -D
option. For example -DUSB_OTG_HS_CORE or -DUSB_OTG_FS_CORE . I don't
know if the example is made for highspeed of fullspeed but it should be
save to use the same settings as in the examples.
Another option is to define one of the macros in a header-file which is
included by all USB-codes. IRC there is such a file in the STM library,
somthing like usbconf.h. Further information should be available in the
manual of the STM32F-USB-Library. The STM32-forum at st.com might be a
better place to ask such target-specific questions.
Hope this helps,
Hello Martin,
               Many thanks for your reply, I will try both options and
post my progress.I agree STM32 forum would be a good choice. My choice
for this forum was based on google results, and the fact that  some one
had faced similar problem in the german version of the forum.
