Forum: FPGA, VHDL & Verilog FIFO in VHDL
von nick k. (Company: university) (tonionio)
Hi there guys!
I want to build a router in order to use it as a generic component to
build a mesh interconnections networks of 64 cores.
So to begin with I must build the one router.
I am planning in using the FIFO for input buffer an FSM to control the
read and write a XY logic element for routing the same for the output
only there I ll use an arbiter to arbitrate the request and a central
crosspoint matrix.
Soto begin with I want to build the FIFO having inputs of :data in ,clk,
write,read and outsof : the first4bits of the header are used for
routing ,data out,fifo full, fifo empty.
Thank you in advance.
von PittyJ (Guest)
Open Quartus II
Menu 'Tools' -> 'Megawizard Plugin Manager'
Select 'Memory Compilier' -> Fifo
Enter your parameters.
Or
Open ISE
'Tools' -> 'Core Generator'
'Memory & Storage Elements' -> Fifo
I am getting a message there is now project open!I have opened a new
project but again I cannot load the fifo!
:( Is it because I have the free version of ISIM?
Ok I have done it...But I dont really know how to set the right
parameters before generating it :(
I need Data input ,clk,write and read , and outputs :first 4 bits of
header for routing , dataout ,fifofull,fifoempty.
Can I implement these ports to have the requesting fifo?
von PittyJ (Guest)
I think, you should sit down, take some books and Xilinx documents and
read about the basics.
Look, what Xilinx offers you in their fifo-design. And then look, what
signals you have to combine for your purpose.
I think you are right and thats what I am doing...
Any suggestions on books or xilinx documents?
von P. K. (pek)
Go to Google, enter "xilinx ise fifo generator" and take what you think
fits best your needs.
Have a nice weekend... ;-)
Could I please ask how can I testbench a core generator FIFO?
I mean I have done all the steps to generate the fifo with the i/o i
need and I cannot understand what to do next  to tb it!
Will I have to write the tb?Is there a tb ready in the core to use?
cheers :)
von Duke Scarring (Guest)
Yes, I think so.
Normally you have a global system, where the FIFO is only a small part.
I do normally a simulation of the global system...
I don't think so. FIFO is not MIG.
Duke
von Van Loi L. (fpga4student)
nick k. wrote:
> Hi there guys!
> crosspoint matrix.
Example Verilog/VHDL code for FIFO memory:
http://www.fpga4student.com/2017/01/verilog-code-for-fifo-memory.html
http://www.fpga4student.com/2017/01/vhdl-code-for-fifo-memory.html
