Forum: FPGA, VHDL & Verilog VHDL code 3 bit multiplier using half adder and full adder and also and gate
von hor c. (vandread)
i try to do the vhdl code for 3 bit multiplier but i getting confuse and
confuse when try to create the code can someone help me??
von PittyJ (Guest)
Let the VHDL compiler make it for you.
signal a:integer range 0 to 7:=5 ;
signal b:integer range 0 to 7:=6;
signal c:integer range 0 to 16 :=7;
signal result : integer range 0 to 127;
begin
  Timer: process (Clock_50MHz) is begin
    if rising_edge(Clock_50MHZ) then
       result <= a*b+c;
       a      <= a -1;
    end if;
  end process;
ehhh...dun understand....i using quartus 2 altera web edition, can it
make something like this??
von PittyJ (Guest)
Why do you not check it out? Enter your code and let quartus synthesize
it!
Where ist the problem to test it out?
Show what you have and report whats the problem with it. Then someone
might help you, but we intend not to do your homework completely...
