Forum: FPGA, VHDL & Verilog debug of a vhdl code for a digital integrator
von Pratyush A. (pratyush23)
I m trying to work on a digital integrator..i have the verilog code of
the integrator as follows...
module dig_int(output reg y, input x,clock);
  reg z='b0;
  always @(x,z)
  y=x+z;
  always @(posedge clock)
  z<=y;
endmodule
i used x-hdl to convert it to a vhdl equivalent..and the code generated
was as follows...
LIBRARY ieee;
   USE ieee.std_logic_1164.all;
   USE ieee.std_logic_unsigned.all;
ENTITY dig_int IS
   PORT (
      y      : OUT STD_LOGIC;
      x      : IN STD_LOGIC;
      clock  : IN STD_LOGIC
END dig_int;
ARCHITECTURE trans OF dig_int IS
   SIGNAL z       : STD_LOGIC := '0';
   SIGNAL y_xhdl0 : STD_LOGIC;
BEGIN
   y <= y_xhdl0;
   PROCESS (x, z)
   BEGIN
      y_xhdl0 <= x + z;
   END PROCESS;
   PROCESS (clock)
   BEGIN
      IF (clock'EVENT AND clock = '1') THEN
         z <= y_xhdl0;
      END IF;
   END PROCESS;
END trans;
on synthesis of the above vhdl code, there is an error in the line
y_xhd10 <= x + z;
please suggest as to how to rectify the above problem..or any other prb
so that the code can be run error-free
thanks.
von Holger Bachwieser (Guest)
you require to use std_log_vecor to use them as counters but it is a
widely afreed fact that numeric should be your library when intending
calculations
> y_xhd10 <= x + z;
Be more specific: what error?
Your code is missing a library for std_logic arithmetics...
Or much better: use numeric_std for calculations.
>> y_xhd10 <= x + z;
the following error was reported...
ERROR:HDLParsers:808 - "E:/lgkfmg/kjnj.vhd" Line 49. + can not have such
operands in this context.
i included the following libraries...
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.numeric_std.ALL;
...yet the problem persists...
> calculations
You cannot add two single bits together! What sense should that make?
Instead you can:
1. understand what you want to do and simply EXOR those two bits
Or
2. Use single bit vectors  like this:
    SIGNAL z : STD_LOGIC_VECTOR( 0 DOWNTO 0);
And never ever use the std_logic_arith libs together with the
numeric_std...
