Well at least it seems tricky. Here's the problem:
I'm using DMA on a Cortex-M3. DMA requires an array in RAM of 32
structures to be used by the CPU for housekeeping. Each struct
represents one DMA channel and consumes 16 bytes each. That's 512
bytes, mostly wasted. Why?
Of those 32 DMA channels, numbered 0 - 31, I'm using only one, channel
29. This means in that 512 byte array, members 0 - 28 and 30 - 31 are
unused. The datasheet says array members associated with unused DMA
channels can be used for something else. Easily said, not as easily
done.
To make it worse, the start of the array must be 1024-byte aligned.
This results in more wasted RAM because of the alignment. Apparently
GCC can't arrange other RAM assignments any better.
All that's required to set up this array is to declare it, then program
the array's address into a specified CPU register.
So what I was thinking is this: Declare only the 16 byte struct I need,
and, align it such that it's 464 bytes from a 1024 byte boundary. I
think there's some linker/makefile methods to use, like
--section-start=.MySection=org along with _attribute_ ((section
(".MySection"))), but this didn't work since it displayed .MySection in
the .map file but put other variables in it's space.
jrmymllr jrmymllr wrote: > I'm using DMA on a Cortex-M3. The Cortex-M3 does not have any DMA. The controller however may have both a Cortex-M3 core and DMA. So while it is nice to know the processor core, it would help more to know the type of controller.
It's a TI LM3S9B92, however I didn't think even the core type made a difference since I'm only trying to locate a RAM struct in a specific location.
> To make it worse, the start of the array must be 1024-byte aligned. > This results in more wasted RAM because of the alignment. Apparently > GCC can't arrange other RAM assignments any better. Have you tried the gcc option "-fdata-sections"? The linker works only with whole sections IIRC. How did you tell gcc about the 1024 Byte alignment?
I have not tried that yet, but will look into it. The alignment was done with _attribute_ ((aligned(1024)));
You may have to use your own section and setup the linker configuration to place the section with the required alignment, and the data block within this section. Likely the regular data section does not have a 1024 byte alignment and therefore the alignment attribute within the section cannot be satisfied. In the linker script, you can subtract the 1K block from top of RAM assigned to normal RAM allocation and use this 1K block for the DMA section. Since your channel is located near the end of this 1K block, the block need not be configured for full 1K though, so you can reuse the lower channels space for top of regular RAM.
The problem here is that freeing up the lower channels is easy; I simply
don't make the array any longer than I need to. It's the upper channels
that's the problem, and use the most memory.
My plan was to choose a hard address that meets the requirement. If I
could get the linker to not allocate anything to a 16 byte block of my
choosing, this would solve the problem. For example, 464 bytes from the
start of the RAM (0x2000 0000) would do. Those 464 bytes before, and the
rest of the 96K after would be free to give the linker.
Problem is, I haven't figured out yet how to talk in the language of the
linker file.
Below is my linker file, written by TI from an example:
MEMORY
FLASH (rx) : ORIGIN = 0x00001000, LENGTH = 252K
SRAM (rwx) : ORIGIN = 0x20000000, LENGTH = 96K
SECTIONS
.text :
KEEP(*(.isr_vector))
*(.text*)
*(.rodata*)
_etext = .;
} > FLASH
.data : AT (ADDR(.text) + SIZEOF(.text))
_data = .;
*(vtable)
*(.data*)
_edata = .;
} > SRAM
.bss(NOLOAD) :
_bss = .;
*(.bss*)
*(COMMON)
_ebss = .;
. = ALIGN (8);
_end = .;
} > SRAM
/* end of allocated ram _end */
PROVIDE( _HEAP_START = _end );
/* end of the heap -> align 8 byte */
PROVIDE ( _HEAP_END = ALIGN(ORIGIN(SRAM) + LENGTH(SRAM),8) );
For a complete 1K DMA region:
MEMORY
SRAM (rwx) : ORIGIN = 0x20000000, LENGTH = 95K
DMA (rmx) : ORIGIN = 0x20017C00, LENGTH = 1K
SECTIONS
.text :
*(.text*)
*(.rodata*)
_etext = .;
} > FLASH
_data = .;
*(vtable)
*(.data*)
_edata = .;
} > SRAM
.bss(NOLOAD) :
_bss = .;
*(.bss*)
*(COMMON)
_ebss = .;
. = ALIGN (8);
_end = .;
} > SRAM
.dma(NOLOAD) :
*(.dma)
} > DMA
And use "__attribute__" to place the DMA block into section ".dma".
When only channels 28+ are used, you may use this method to allocate 128
bytes instead of 1024 bytes at top of RAM:
SRAM (rwx) : ORIGIN = 0x20000000, LENGTH = 98176
DMA (rmx) : ORIGIN = 0x20017F80, LENGTH = 128
In this case you have to mask the low order bits of the DMA block base
address address when configuring the DMA controller. Or calculate a
linker variable in a way similar to _HEAP_END.
I was going to say the control structure is 512 bytes, not 1K, and this won't work. However I believe I can specify the alternate control structure, which would make the entire DMA control block 1K. The required DMA channel in this case would end only 32 bytes from the end of the 1K, meaning I waste only 32 bytes with not much hassle. And, one of those two channels at the end I could potentially use in the future. Many thanks for the linker script, I will give this a try later.
