Forum: FPGA, VHDL & Verilog Help with VHDL code - Digital Audio Meter project
von Josh G. (joshgow)
Hi Folks,
I need help to mod the code for  this FPGA based (Altera CycloneII
EP2C5T144) Digital Peak Level Meter:
http://www.beis.de/Elektronik/DPLCM/DPLCM.html
The code is available at the bottom of the page.
The problem:
I don't need the SPDIF feature, so I would like to implement
an I2S input, which would be directly connected to the output of the
A/D Converter.
The I2S lines are:
BCK (Serial Bit Clock)
WS (Word Select, or LRCLK)
SDI (Audio Serial Data Input)
The I2S timing and standard description can be found at:
http://www.classic.nxp.com/acrobat_download2/various/I2SBUS.pdf
Can anyone help?
Thanks in advance.
> Can anyone help?
Cut out the SPDIF-Rx.vhd and replace it by your I2S-Rx.vhd
Inside this I2S-Rx.vhd you have to implement the I²S decoder. And thats
fairly simple: for sure the I²S decoder will cost less than 50 lines of
code...
Data afterwards is passed to the upper level module by
AudioData0  : out std_logic_vector(23 downto 0);
AudioData1  : out std_logic_vector(23 downto 0);
> Can anyone help?
With what?
Pls ask more specific questions instead of "who can do my work?"
Lothar Miller wrote:
>> Can anyone help?
> code...
>> Can anyone help?
> With what?
Who can do my work:
I should have been clearer: I'm not a programmer, it's not my work. I
wouldn't know where to start.
So the help is for the code itself.
von Manni (Guest)
Did you manage to run the I2S Interface? This would be interesting to my
too.
