Forum: ARM programming with GCC/GNU tools Problem with gnu ld and STM32
Author: Thomas H. (Guest)
Hello,
I'm trying to make anSTM32F103 work with the Code Sourcery tool chain.
Using the attached ld command file, I get these errors:
Invoking: Cross GCC Linker
gcc -L"/home/Tommi/workspace/FWLib/Release" -Wl,-T ../SRC/STM32_Lnk.cmd
-o "LED01"  ./SRC/core_cm3.o ./SRC/main.o ./SRC/startup_stm32f10x_hd.o
./SRC/stm32f10x_it.o   -lFWLib
collect2: ld terminated with signal 11 [Segmentation fault]
/home/Tommi/CodeSourcery/Sourcery_CodeBench_Lite_for_ARM_GNU_Linux/bin/.
./lib/gcc/arm-none-linux-gnueabi/4.6.1/../../../../arm-none-linux-gnueab
i/bin/ld:  BFD (Sourcery CodeBench Lite 2011.09-70) 2.21.53.20110905
assertion fail
/scratch/jwlemke/2011.09-arm-linux-eabi-lite/obj/binutils-src-2011.09-70
-arm-none-linux-gnueabi-i686-pc-linux-gnu/bfd/elf32-arm.c:7504
assertion fail
assertion fail
assertion fail
-arm-none-linux-gnueabi-i686-pc-linux-gnu/bfd/elf32-arm.c:13826
make: *** [LED01] Fehler 1
**** Build Finished ****
What is wrong?
Thanks for your help,
Tommi
Author: Klaus Wachtler (mfgkw)
Thomas H. wrote:
> Hello,
Are you sure you want to invoke gcc?
This will probably be your local compiler/linker.
I don't know your toolchain, but I would assume the compiler/linker
could look like arm-anything-gcc.
Ok, I forgot:
I'm working on Linux, first in my path is a local directory that
contains symbolic links to the CodeSourcery tools. The message:
i/bin/ld:
BFD (Sourcery CodeBench Lite 2011.09-70) 2.21.53.20110905 assertion fail
tells me, that I actually invoke "arm-none-linux-gnueabi/bin/ld"
Right?
Ok, I found it:
I downloaded arm-none-linux-gnueabi because I am working on linux as
development platform. Bad idea! This is for building application with a
linux on the target.
I should have downloaded arm-none-eabi, which is the 'bare metal' tool
chain for a 'naked' controller.
I'm starting over now, following the "getting-started" that was provided
with the tool chain.
