Forum: FPGA, VHDL & Verilog c-code function into VHDL?
von Fito (Guest)
i have to calculates lots of constants, dependant only of 1 generic
value. I can do that in C or in Octave (Matlab-like language).
I don know how to load those constants, i've been doing it "by hand" in
the VHDL header, first calculating them, and them putting them into
matrixes in an array type. Can i implement the c-code (or matlab code)
into the vhdl code like some kind of function? Have in mind that i'm not
asking for sinthetizing this secuential code for calculation, i'm just
looking for the ability to know the number of components and length of
signals by every "layer" in my design.
Thanks a lot
von Basti Sch. (Guest)
Hi Fito,
you might need to store your constants in a textfile and overwrite your
constants(generics) with this values. Look for the textIO package.
Regards
von Nikolaos K. (Company: http://www.nkavvadias.com) (nikolaos_k)
Hi Fito
check out my solution:
http://www.nkavvadias.com/hercules/
and for free testing:
http://www.nkavvadias.com/cgi-bin/herc.cgi
These links provide access to the HercuLeS high-level synthesis tool. So
you can try automatically synthesizing your C code to VHDL with Herc.
Best regards
Nikolaos Kavvadias
Research Scientist
von Thomas R. (Company: abaxor engineering) (abaxor)
Write a function in C/Octave, which generates a valid VHDL file,
containing your constants. Add this file to your project.
Tom
von Morbus (Guest)
Maybe myHDL (http://www.myhdl.org/doku.php) could solve your problem,
but it might be quite a change.
For simulation, some people have done interesting stuff with the GHDL
simulator by interfacing it with C routines
(http://www.fpgarelated.com/showarticle/20.php). But not sure if that
helps, as you're speaking of constants. I'm just using those extensions
to pull configuration values out of .INI files.
von Hocko (Guest)
once, there used to be a prog named "c to vhdl" I got from the internet
i never tried
