Forum: FPGA, VHDL & Verilog error (10346)
von miri (Guest)
This error on quartus: formal port or parameter "N" must have actual or
default value
What does it mean?
Here is my code:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_signed.all;
entity shrBbits is
  generic (N:positive);
  port( A,B: in std_logic_vector(N-1 downto 0);
        OP: in std_logic_vector(2 downto 0);
        RES_LO:out std_logic_vector(N-1 downto 0)
end entity;
von lkmiller (Guest)
Write
(N:positive :=8)
von miri p. (miripek)
I have this code:
Doing a shift to A - B times.
entity shrBbits is
  generic (N:positive:=32);
end entity;
architecture behv of shrBbits is
signal temp,temp_res: std_logic_vector(N-1 downto 0);
signal num:integer:=0;
begin
  process (A,B,OP,num,temp,temp_res)
  begin
  temp<=A;
  temp_res<=A;
  if (conv_integer(B)<0) then --for negative B
    num<=conv_integer(not (B))+1;
  else if num=0 then
      temp_res<=A;
      num<=conv_integer(B);
     else
     end if;
  end if;
  temp_res(N-1 downto num+1)<= temp(num-1 downto 0); -- HERE IS THE
ERROR
  temp_res(num downto 0)<=temp(N-1 downto num);
  RES_LO<=temp_res;
  end process;
end behv;
How can it be changed?
>-- HERE IS THE ERROR
WHAT error?
  temp_res(N-1 downto num+1)<= temp(num-1 downto 0); -- HERE IS THE ERROR
No.
Your error happens much before!
How does a signal react in an process?
How does a variable react in a process?
However:
Calculate this for N=32 and lets say num=3:
  temp_res(31 downto 4)     <=     temp(2 downto 0);
   this vector ^^^^  is MUCH longer than  ^^^^ this vector...  :-o
Yes - thanks - you right
it should be:
  temp_res(N-1 downto N-num)<= temp(num-1 downto 0);
  temp_res(N-num-1 downto 0)<=temp(N-1 downto num);
But it still gives me the same error.
Why?
Assume num could become zero...
And beware: you will get latches for num also, because num is stored
without a clock!
I have to do this task without clock?
It's strange to do it this way, but still, do you have some ideas to
work it out?
thanks
One question in advance:  can B become negative?
No. B is positive.
> No. B is positive.
So, why that:
Really a shift?
A right shift or a left shift?
Or (as you do) a rotation?
With your name sh-r-B-bits I assume a right shift for B bits:
library IEEE;
use IEEE.numeric_std.all;
entity shrBbits is
  port( A,B: in std_logic_vector(N-1 downto 0);  -- why is B that big? 6 bits (0..32) would be enough!!!
        OP: in std_logic_vector(2 downto 0);     -- what is this OP good for?
end entity;
signal num  : integer range 0 to 2*N:=0;
signal hlp  : std_logic_vector(N*2-1 downto 0);
begin
   --  used ressources and delay times are for a Spartan 3 AN
   --  Number of Slices 75
   --  Maximum combinational path delay: 10.832ns
   process (A,B)
   variable h : std_logic_vector(N-1 downto 0);
   variable c : integer range 0 to N:=0;
   begin
      h := A;
      c := to_integer(unsigned(B));
      for i in 0 to N-1 loop
         if i<c then
            h :=  '0' & h(N-1 downto 1);
         end if;
30
      end loop;
31
      RES_LO <= h;
32
   end process;
33
34
35
  -- Maximum combinational path delay: 10.912ns
36
  process (A,B)
37
38
39
  begin
40
     h := A;
41
42
43
        if i=c then
44
           exit;
45
        end if;
46
47
     end loop;
48
     RES_LO <= h;
49
  end process;
50
51
  -- Number of Slices 79
52
  -- Maximum combinational path delay: 11.445ns
53
  process (A,B)
54
55
56
  begin
57
58
     h := (others=>'0');
59
     h(N-1-c downto 0) := A(N-1 downto c);
60
     RES_LO <= h;
61
  end process;
62
63
  -- Number of Slices 82
64
  -- Maximum combinational path delay: 11.536ns
65
  num <= to_integer(unsigned(B));
66
  hlp <= x"00000000"&A;
67
  RES_LO <= hlp(N-1+num downto num);
68
69
end behv;
The last one can easily be changed to a rotate function:
   hlp <= A&A;
I tested the code above with the attached stimuli "testbench".
For
 process (A,B)
  begin
     h := (others=>'0');
     RES_LO <= h;
  end process;
I still have an error "right bound of range must be constant".
What else might it be
Here is the full code:
library IEEE;
use work.pack.all;
-- this unit shift A bits number of B times to the right
-- if B is negative or zero the result is still A
-- the result is in res_shr
entity shrBbits is
  port( A: in std_logic_vector(N-1 downto 0);
        RES_SHR:out std_logic_vector(N-1 downto 0)
end entity;
begin
  process (A,B)
  begin
     c := conv_integer(unsigned(B));
     h := (others=>'0');
     RES_SHR <= h;
  end process;
end behv;
Thanks for the help,
Miri
I have this error while running Quartus
Lets say: except the missing definition of N...
I changed the code a little:
entity shrBbits is
  generic( N : integer := 16);
  port( .... );
end entity;
What toolchain?
EDIT: too late... :-/
With Xilinx XST this works fine...
BTW: you did see this in my code?
library IEEE;
Yes? Think about it...
A hint: the Synopsys libs are obsolete a long time ago and superseeded
by the numeric_std.
BTW2: with
[ vhdl]
and
[ /vhdl]
(but without the blanks) and you can see a little magic:
and
Quartus 64 bits.
tool chain - modelsim
von berndl (Guest)
I'm not sure, but I think the problem with Quartus is:
ISE and Lattice Diamond can handle this, but Quartus may have a problem
with this statement.
You could try to use a 'for i in 0 to N-1 loop' and assign just bitwise
von Amina A. (Company: lebanon) (sweetamo)
This error on quartus:Error (10346): VHDL error at accumu.vhd(18):
formal port or parameter "m" must have actual or default value
What does it mean?
Here is my code:
library ieee;
use ieee.std_logic_1164.all;
library work;
use work.all;
entity acc is
port(x,y: in std_logic_vector(3 downto 0);
selacc,selpm,key: in std_logic;
somme: out std_logic_vector(3 downto 0));
end entity acc;
architecture structure of acc is
signal x0,x1,x2: std_logic_vector(3 downto 0);
begin
u0: mux2to1 port map(m0=>x,m1=>x1,mout=>x0, sel=>selacc);
u1 : adder4 port map(a=>y,b=>x0, sel=>selpm, cout=>open,z=>1);
u2:registre port map(clk=>key,d=>x1,q=>x2);
somme<=x2;
 end architecture structure ;
library ieee;
library work;
use work.all;
entity adder4 is
30
port(m,n:in std_logic_vector(3 downto 0);
31
cin:in std_logic;
32
cout:out std_logic;
33
p:out std_logic_vector(3 downto 0));
34
end entity adder4;
35
36
architecture structure of adder4 is
37
signal c0,c1,c2:std_logic;
38
begin
39
fa0: fa port map(y=> m(0),x=> n(0),cin=>cin,s=>p(0),cout=>c0);
40
fa1: fa port map(y=> m(1),x=> n(1),cin=>cin,s=>p(1),cout=>c1);
41
fa2: fa port map(y=> m(2),x=> n(2),cin=>cin,s=>p(2),cout=>c2);
42
fa3: fa port map(y=> m(3),x=> n(3),cin=>cin,s=>p(3),cout=>cout);
43
end architecture structure;
44
45
46
library ieee;
47
48
entity mux2to1 is
49
port(m0,m1:in std_logic_vector(3 downto 0);
50
mout:out std_logic_vector(3 downto 0);
51
sel:in std_logic);
52
end entity mux2to1;
53
architecture behavior of mux2to1 is
54
begin
55
mout<=m0 when (sel='0')else m1;
56
end architecture behavior;
of course each i wrote each entity in a vhdl file
Amina Amin wrote:
> Here is my code
Why do you not use some indetion to get a kind of readable code...
You can have it in one file also, thats no problem. Or you could attach
each of the files here, so it would be easier to find that line 18 in
accumu.vhd...
However: what about simply using the same names for the port signals in
the entity and in the port list?
u1 : adder4 port map(a=>y, b=>x0, sel=>selpm, cout=>open,z=>1); -- a,b,sel,cout and z
entity adder4 is
port(m,n:in std_logic_vector(3 downto 0); -- m,n,cin,cout and p
cin:in std_logic;
cout:out std_logic;
end entity adder4;
