Forum: FPGA, VHDL & Verilog vhdl code for stuck at faults
Author: sreeram sam (sresam89)
dear all
can anyone please give me a piece of vhdl code for stuck at faults
stuck-at-0 and stuck-at-1 for any sequential and/or combination
circuits, just need it to start from the scratch.
I OWE you members..
Author: user (Guest)
stuck at 0 is a AND with a control input, control input = 0 inserts a
fault
stuck at 1 is a OR  with a control input, control input = 1 inserts a
fault
So you want to recognize a stucked/failed signal? Then define a
stuck-at-1: how long must the signal be '1' to be stucked at '1'?
Or do you want to memorize a fault signal (even when the fault
disapears) to see later, that there was a fault? Then you need a latch.
What do you want to do with the code? Is it "just" for a test bench? Or
is it for a "real" hardware (FPGA)?
yes i need to recognize the fault, the code is for simulation only
purpose only not for any implementation.
the fault may be a permanent one for a particular circuit. i dont want
to use a latch and complicate code so much.
thanks Miller
Try this as a concurrent statement (without any process):
    assert not(now>0 ns and sig='1' and sig'quiet(300 ns))
        report "sig stuck at '1' for 300ns" severity warning;
    assert not(now>0 ns and sig='0' and sig'quiet(400 ns))
        report "sig stuck at '0' for 400ns" severity warning;
kindly give me the declaration parts also.(entity port)
thanks
Because you want to use this code in a test bench, there is no port in
the entity.
You can use this code snippet for any signal in any architecture in any
part of your design. So the only thing missing is:
   signal sig : std_logic := '0';
And if your signal is named toggle then the stuck-at-one test will
read:
    assert not(now>0 ns and toggle='1' and toggle'quiet(300 ns))
        report "toggle stuck at '1' for 300ns" severity warning;
> the entity.
> read:
so can i have this snippet at the end of my work space before i end the
architecture?
will tat way work?
If I were YOU, then I would simply TRY it that way...  :-/
  • [vhdl]VHDL code[/vhdl]
