Forum: FPGA, VHDL & Verilog URGENT. Help on 4bit counter.
Author: Karthiga G. (karthiga05)
Hi. this is my vhdl code for a 4 bit counter using 1 half adder and 3
fulladders. i have done my code. bt the waveform only shows "0000" and
"0001". aftr "0001", it doesnt add anymore. how do i do that? Thanks in
advance!
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity counter4 is
   port(count:out std_logic_vector(3 downto 0);
        clk:in std_logic;
        reset:in std_logic);
end counter4;
architecture behav_counter4 of counter4 is
   component ha port (a: in  std_logic;
                      b: in  std_logic;
                      sum: out std_logic;
                      c_out: out std_logic);
   end component;
   component fa port (a, b, cin : in std_logic;
                      sum, c_out : out std_logic);
   end component;
   signal ain,s,c:std_logic_vector(3 downto 0) :="0000";
   signal bin:std_logic_vector(3 downto 0):="0001";
   --configuration specification
   for all:ha use entity work.ha(rtl);
   for all:fa use entity work.fa(fa_behav);
   begin
      u1:ha port map(a => ain(0), b => bin(0), sum => s(0), c_out => c(0));
      u2:fa port map(a => ain(1), b => bin(1), sum => s(1), cin => c(0), c_out => c(1));
      u3:fa port map(a => ain(2), b => bin(2), sum => s(2), cin => c(1), c_out => c(2));
      u4:fa port map(a => ain(3), b => bin(3), sum => s(3), cin => c(2), c_out => c(3));
      counter:process(clk, reset) --process(sensitivity list)
      begin
         if reset'event and (reset = '1') then
            s <= (others => '0');
         elsif clk'event and (clk='1') then
            ain <= c xor ain;
            s <= ain xor bin;
            c <= s and c;
         end if;
      end process;
      count <= s;
end behav_counter4;
This is not the complete description. I do not see anything about the
components ha and fa.
And as far as I see: if your ha and fa are working and the wiring is ok,
the only thing you must do in the process is this
      begin
         if (reset = '1') then
         elsif (clk'event and clk='1') then
            ain <= s;
         end if;
      end process;
And why?
Because the adder should do s=a+b.
With b=1 it does s=a+1.
And so for a counter you must just say a(new)=s(old) for each clock
cycle.
Whats that?
A clock sensitive reset? Thats not possible with real flipflops!
Author: Duke Scarring (Guest)
Homework?
Write:
begin
 if reset = '1' then
Otherwise it will only react if there are events on reset signal...
Duke
Another little problem:
Because the sum s is a result of a combinational calculation, its not
possible to reset it in a process.
But you can reset the counter flipflops. And these are the ain
flipflops, because they are affected by the clock. so it must look like
this:
      begin
            ain <= (others => '0');
            ain <= s;
         end if;
      end process;
Duke Scarring wrote:
> Homework?
> Write:
> begin
>  if reset = '1' then
> Duke
Now is shows 000X, 00XX and 0XXX only. its still not looping.
i used "if reset'event and (reset = '1') then
            s <= (others => '0'); "
for my 8 bit counter and it worked.
OMG! IT WORKS NOW!! THANK YOU SO MUCH!
And whats your code now?
Next time, tell your professor or teacher the world use "+" to make an
addition:
library ieee;
use ieee.numeric_std.all;
entity counter4 is
    port(
        count : out std_logic_vector(3 downto 0);
        clk   : in  std_logic;
        reset : in  std_logic
end entity counter4;
    signal s : unsigned(3 downto 0) := "0000";
    counter : process(clk, reset) -- process(sensitivity list)
    begin
         if reset = '1' then
         elsif rising_edge( clk) then
            s <= s + 1;
         end if;
    end process;
    count <= std_logic_vector( s);
end architecture behav_counter4;
She or he needs an recent textbook...
Duke
But, Duke, EVERYBODY MUST write a RTL adder to understand how an
addition is working in hardware...  ;-)
    begin
         if reset = '1' then
            s <= s + 1;
         end if;
    end process;
Thats the most ancient way to write an adder. This comes just after the
RTL code.
For todays FPGAs (Xilinx) it may be good to use a synchronous reset:
    counter : process(clk)
    begin
            if reset = '1' then
            else
               s <= s + 1;
            end if;
         end if;
    end process;
This also will work in the same manner:
    counter : process -- NO sensitivity list
    begin
        wait for rising_edge(clk);
        if reset = '1' then
        else
           s <= s + 1;
        end if;
    end process;
>     begin
>          if reset = '1' then
>             s <= s + 1;
>          end if;
>     end process;
i cant use 's = s+1'.
library ieee;
entity counter4 is
        clk:in std_logic;
end counter4;
                      b: in  std_logic;
                      sum: out std_logic;
   end component;
   end component;
   begin
c(0));
c_out => c(1));
c_out => c(2));
c_out => c(3));
      begin
      if reset = '1' then
         ain <= s;
         end if;
      end process;
      count <= s;
end behav_counter4
my waveform starts from 0001. and the reset is uninitialized at the
beginning. i need to start my counter frm 0000. hw do i do that?
Can you post a screenshot of your simulation?
Can we see yout testbench?
Duke
attached is my waveform and my testbench is below.
library ieee;
entity mycounter_testbench4 is
end mycounter_testbench4;
architecture mycounter_tb4 of mycounter_testbench4 is
   signal count: std_logic_vector(3 downto 0):="0000";
   signal clk: std_logic:='0';
   signal reset: std_logic;
   component counter4
      port(count:out std_logic_vector(3 downto 0):="0000";
           clk:in std_logic:='0';
   end component;
      begin
      counter_circuit : counter4
         port map(count => count, clk => clk, reset => reset);
            clock:process
               begin
                  wait for 10ns;
                  clk <= not clk;
            end process clock;
            test_reset:process
               begin
                  wait for 5ns; reset <= '1';
                  wait for 4ns; reset <= '0';
                  wait;
            end process test_reset;
end mycounter_tb4;
Your adder is combinatoric. And your output (count <= s;) is also
combinatoric. You can put "count <= s;" in the clocked process...
Duke
what is combinatoric?
it still doesnt start frm 0000. it starts frm 0001.
Thats correct: ain is initialized as "0000".
And with s=ain+1 this results in "0000"+"0001"="0001"
So just try to initialize ain with "1111", because "1111"+"0001"="0000"
> signal ain :std_logic_vector(3 downto 0) :="1111";
it still starts with 0001. and not 000o although ive changed the initial
values to 1111.
4bitcount.vhd:
library ieee;
entity counter4 is
        clk:in std_logic;
end counter4;
                      b: in  std_logic;
                      sum: out std_logic;
   end component;
   end component;
   signal ain,s,c:std_logic_vector(3 downto 0) :="1111";
   begin
      begin
         if reset = '1' then
            ain <= s;
            count <= s;
         end if;
      end process;
end behav_counter4;
testbench:
library ieee;
   signal count: std_logic_vector(3 downto 0):="1111";
   component counter4
      port(count:out std_logic_vector(3 downto 0):="1111";
   end component;
      begin
            clock:process
               begin
                  wait for 10ns;
                  clk <= not clk;
            end process clock;
            test_reset:process
               begin
                  wait;
end mycounter_tb4;
Pls show the code of your components fa and ha also.
> initial values to 1111.
NOW it is time to start THINKING on your own.
Just with a few clicks in the simulator i fixed the problem with your
code:
library ieee;
entity ha is
         b: in  std_logic;
         sum: out std_logic;
end ha;
architecture rtl of ha is
begin
   sum   <= a xor b;
   c_out <= a and b;
end rtl;
library ieee;
entity fa is
end fa;
architecture rtl of fa is
begin
   sum   <= a xor b xor cin;
   c_out <= (a and b) or (a and cin) or (b and cin);
end rtl;
library ieee;
entity counter4 is
   port(count: out std_logic_vector(3 downto 0);
        clk  : in std_logic;
        reset: in std_logic);
end counter4;
                      b: in  std_logic;
                      sum: out std_logic;
   end component;
   end component;
   for all:fa use entity work.fa(rtl);
   begin
      begin
         if reset = '1' then
            ain   <= "1111"; -- Set here the initial value also
            ain   <= s;
         end if;
      end process;
      count <= s;
end behav_counter4;
REMIND this: because i didn't have your adders, i had to use mine.
You can do it this way also:
                      b: in  std_logic;
                      sum: out std_logic;
   end component;
   end component;
   signal ain,s,c : std_logic_vector(3 downto 0);
   signal bin : std_logic_vector(3 downto 0) :="0001";
   signal cnt : std_logic_vector(3 downto 0) :="0000"; -- these are the counter registers
   begin
      begin
         if reset = '1' then
            cnt   <= "0000";
            cnt   <= s; -- take over the next value
         end if;
      end process;
      ain   <= cnt; -- connect the counter value to the adder input
      count <= cnt; -- pass to output
end behav_counter4;
Here the counter registers are explicitly declared, and therefore the
adder itself is completely combinatorial.
  • [vhdl]VHDL code[/vhdl]
