Forum: ARM programming with GCC/GNU tools why doesn't sprintf( ) work?
Author: Mike P (Guest)
i'm new to GCC/Gnude and have been through a lot of makefile trouble
which is finally solved but it appears i still have one remaining
problem.
sprintf( ) doesn't work.  strcpy & strcat work fine.  i suspect there's
a library initialization that isn't being called for some reason.  the
code worked fine when i used the keil compiler.
sprintf(s, "Day %d", 1)
i have looked for the source for sprintf but have never found it.
truthfully, i'm also not sure i'm looking in the right place.
I imagine i should be looking at http://www.gnu.org .  i found some
source but never managed to find what i'm looking for.
thank you!
mp
Is there enough stack-space available? Is the heap initilalized? Does
the linker set the "end"-symbol correctly?
>the code worked fine when i used the keil compiler.
I expect you do not use the "Keil compiler" (very outdated) but the
Realview toolchain which comes with MDK-ARM but this will not help
anyway. The interfaces for stdio functions like sprintf are standardized
but the implementions are different.
stio-functions like sprintf are part of the libc. Most binary
disitributions for the GNU ARM-cross-toolchain use the newlib as libc.
If you are using such a package you will find the sources in the newlib
CVS:
http://sourceware.org/cgi-bin/cvsweb.cgi/src/newli...
As far as I know the compiler can replace calls to sprintf which only
use constant parameters which something like memcopy if optimization is
enabled. Maybe you have found code for this in the gcc-sources but it
will not help with non-constant parameters.
sorry for my slow reply--i've been taking what you've said & tried to
learn some parts that could possibly help me.
sorry, i don't know how.  i'm just using an example.
yes; price
thank you for the source link.  sure is adorned with macros.  didn't see
how to init that library.
in a way, that's probably not my biggest problem because i can't even
make much in the way of calls.  sounds like stack trouble but i don't
know how to fix that.  attached a file for that.
i expect i need to make the linker command line agree with simple.cmd
and makefile and startup.s.  i tried by it was entirely unsuccessful.
can you help me?  i'm not accustomed to being so "stuck".  i'm a
programmer by trade but haven't done much embedded stuff.  what i did do
was arduino and some 8051 assembler.  they were so easy.  Arm is not.
thank you for any help you can provide!
mp
