Forum: µC & Digital Electronics Problem incrementing global int variable in interrut service routine
Author: Tobias K. (tobias_k83)
Hi everyone,
I have a strange Problem: I try to increment a counter inside a
Interrupt Service Routine, but it seems as if it doesn't work whysoever.
The ISR is triggered by a Timer Compare. The counter either gets set
null or gets lost. I tried declaring it volatile, but this didn't work
either. Here the Code in which i unsuccessfully tried sending the memory
address of the counter in the loop and in the ISR:
this goes on your arduino
for use with Processing example SimpleSerialArduinoscope
#include <avr/io.h>
#include <avr/interrupt.h>
   volatile int val[512] = { 0 };
int i = 0;
long u;
void setup() {
  //pinMode(0, INPUT);
  Serial.begin(115200);
  cli();                                     // disable interrupts while
messing with their settings
  TCCR1A = 0x00;                             // clear default timer
settings, this kills the millis() funciton
  TCCR1B = 0x00;
  TCCR1B |= (1 << WGM12);                    // Configure timer 1 for
CTC mode
  TCCR1B &= ~(0 << CS12);                    // Set timer prescaling by
setting 3 bits
  TCCR1B |= (1 << CS11 | 1 << CS10);         // 001=1, 010=8, 011=64,
101=1024
  TIMSK1 |= (1 << OCIE1B);                   // Enable CTC interrupt
  OCR1B  = 5000;                               // Set CTC compare value
  //ADCSRA |= (1 << ADEN);                     // enable ADC
  ADMUX = B01100000;                         // left adjusted output to
increase sample rate, 8bit mode
  SMCR |= (1 << SM0);                        // Enable sleep AD
conversion mode
  SMCR &= ~( (1 << SM2) | (1 << SM1) );
  //SREG |= (1 << ADIE);                       // Enable ADC ready
interrupt
  ADCSRB |= ( ( 1 << ADTS2 | 1 << ADTS0 ) ); // configure ADC to trigger
on Timer Compare Match B
  ADCSRB &= ~(1 << ADTS1);
  sei();                                     // turn interrupts back on
  ADCSRA = B11001111;                         // set ADC prescaler to
128, ADC EN, ADC Start
void loop() {
//  i += 1;
//  if(i==512){
//  i=0;
//u = (long)i;
  Serial.println((HEX)&i);
void tx(){
    cli();
    for (int q=0;q<512;q++){
    Serial.print(val[q]);
    Serial.print(",");
    Serial.println();
    i = 0;
  sei();
void rx(){
ISR(ADC_vect)
//Serial.println((int)ADCH);
  val[i] = (int)ADCH;
  i++;
  if(i==512){
    tx();
The Platform is a Atmel Atmega 1280. Target is to build a simple USB
oscilloscope.
Has anybody an idea what the problem could be?
Thanks in advance,
ToKo
Author: Falk (Guest)
@  Tobias K. (tobias_k83)
i must be volatile too, see article [[Interrupt]].
Regards
Falk
Ahhhh, no links from mikrocontroller.net are working here :-0
http://www.mikrocontroller.net/articles/Interrupt
Author: kbuchegg (Guest)
volatile is one thing.
You need it.
But the other thing is, that you have to make sure, to access i in an
atomare fashion. You failed to do that.
BTW: even if this is a test programm, your ISR does to much lengthy
things and corrupts your timing. Output to the RS232 does not belong in
an ISR.
volatile didnt work either... =(
And please:
leave the Interrupt Enable Bits alone inside an ISR! No cli and sei
That is one sure way to shoot yourself in the knee
volatile ist necessary in that case but it is only half of the story.
atomic access is the other half.
okay, atomic access is totally new to me. how do I do that? How can i
shorten or modify my code so it doesn't corrupt the timing? my plan was
to fill an array and transmit it when it's full.
okay, my idea would be to put the tx() inside an if(i==512)... into
loop, so that cli/sei can be used (and transmission is not disturbed).
but what about atomic access? Did you mean the functions of
<util/atomic.h>?
cleaned version without atomic access:
#include <avr/io.h>
volatile int i = 0;
void setup() {
  TCCR1B = 0x00;
CTC mode
setting 3 bits
101=1024
conversion mode
interrupt
void loop() {
if(i==512){
tx();
void tx(){
    cli();
    Serial.print(",");
    Serial.println();
    i = 0;
  sei();
void rx(){
ISR(ADC_vect)
  val[i] = (int)ADCH;
  i++;
sorry, I am still a bit a kind of noob, is this code better for doing
the job? According to the link above it would be useful if I reduce the
array size to 128 as well as the datatype to Byte to workaround using
ATOMIC_BLOCK(ATOMIC_FORCEON)
right?
Sorry, I meant an array size of 255 -> byte
Iam sure you are a navtive german speaker. So it is much easyer to do so
><util/atomic.h>?
Read the article.
Hi Falk,
richtig geraten =) hab den Artikel gelesen, aber so richtig verstanden
hab ich ihn nicht:
 PINx = (PORTx & 0x0F) ^ lcd_data;
ist laut Artikel die Sollvorgehensweise. Was bedeutet das in meinem
Fall? ich meine Atomarer als val[i]=ADCH gehts ja nicht, oder soll ich
da direkt mit Speicheradressen statt mit val[i] arbeiten? Atomar heißt
ja nur, dass währenddessen nichts anderes ausgeführt werden kann oder?
Author: A. K. (prx)
Das ist eine mögliche Vorgehensweise, aber nur bei Ports, nicht bei
Speichervariablen. Bei denen ist eine dieser ATOMIC_BLOCK Klammern genau
richtig. Und zwar bei jedem Zugriff ausserhalb der ISR.
Nicht atomar kann heissen:
  unteres Byte lesen (alt),
  Interrupt mischt mit und zählt hoch,
  oberes Byte lesen (neu).
Das gibt dann gelesenen Datensalat und ist nur durch temporäre
Abschaltung des Interrupts zu vermeiden.
@Tobias K. (tobias_k83)
>hab ich ihn nicht:
Dann halt nochmal lesen und nachdenken.
Ist ein Sonderfall für IO-Ports bei neueren AVRs. Ungünstiges Beispiel.
> Was bedeutet das in meinem Fall?
Das ist auch OK, weil es in der ISR ist. Die kann nicht unterbrochen
werden (wenn man keine Tricks mit verschachtelten Interrupts macht).
Aber warum nicht val[i]=AWDW; ? Das ist ein einfacher, korrekter,
VOLLSTÄNDIGER Zugriff auf den ADC.
> oder soll ich
Nein.
> Atomar heißt
Sicher, aber das ist auch wichtig. Atomar muss der Zugriff im
Hauptprogramm ein. Warum, steht im Artikel.
AUsserdem ist deine Variante mal wiedr sehr ungünstig. Atomat muss und
sollte NUR das Kopieren der globalen Variable i (ungünstiger Name!) in
eine lokale Variable sein. Die Ausgabe sollte NICHT in den atomaren
Block, weil sie die ganze Zeit deine Interrupts blockiert. Eher so.
#include <avr/io.h>
volatile int i = 0;
void setup() {
  TCCR1B = 0x00;
CTC mode
setting 3 bits
101=1024
conversion mode
interrupt
void loop() {
if(i==512){
tx();
void tx(){
  int tmp;
    cli();
    tmp = i;
    i = 0;
    sei();
      Serial.print(",");
    Serial.println();
void rx(){
ISR(ADC_vect)
  val[i] = ADCW;
  i++;
MfG
Falk
okay, cool. Das heißt
ISR(ADC_vect)
  val[i] = ADCH;
  i++;
passt soweit, nur in der Loop und (?) in tx() kommen die Klammern zum
Einsatz? Habe die Variablen alle mal auf 8bit runtergeschraubt, was ja
die Zwangsatomisierung erübrigen sollte, da kam aber auch nix bei rum...
Vielen Dank schonmal für euer feedback!
Hi Falk,
ich wollte absichtlich nur das High Register lesen, weil man dadurch die
Sampling rate hoch bekommt. hab den ADC auch entsprechend left adjusted
konfiguriert. Werde ich gleich mal probieren, Deine Variante =)
BTW: warum ist i als Name ungünstig?
mist, kann es sein dass ich auch das globale array in ein lokales
kopieren muss? In der Form funktionierts noch nicht...
Das ist ein Name für einen (lokalen) Index oder so, was man halt immer
mal wieder schnell braucht. Globale Variablen sollte man mit
aussagekräftigen Namen versehen, oder z.B. duch eine Vorsilbe ala gTime
(g wie global).
>kopieren muss?
Sicher, dort wird ja auch in der ISR zugegriffen.
MFG
Falk
grrrr... der globale Counter wird immer noch nicht hochgezählt...
Woran erkennst du das?
Poste VOLLSTÄNDIGEN Code als Anhang.
ich sende aus der ISR heraus gCnt
(anhang geht irgendwie nich... hier noch mal gepastet:)
#include <avr/io.h>
//#include <util/atomic.h>
volatile int val[255] = { 0 };
volatile byte gCnt = 0;
void setup() {
  TCCR1B = 0x00;
CTC mode
setting 3 bits
101=1024
conversion mode
interrupt
void loop() {
        if(gCnt==255){
            tx();
void tx(){
 byte tmp;
 int valTmp[255];
    cli();
    tmp = gCnt;
    for(byte i;i<255;i++){
    valTmp[i] = val[i];
    gCnt=0;
    sei();
    for (byte q=0;q<255;q++){
    Serial.print(",");
    Serial.println();
void rx(){
ISR(ADC_vect)
  val[gCnt] = ADCW;
  Serial.print((int)gCnt);
  gCnt += 1;
Öhm, sprach ich nicht von VOLLSTÄNDIGEM Code? Ich sehe kein main()
Ja sorry, hab ich vergessen zu sagen: ich programmiere den Atmega mit
der Arduinoplattform, da gibts meines Wissens kein main.
Okay, ich habe jetzt einfach Ockham's Razor geschwungen und es geht:
ISR(ADC_vect)
Trotzdem vielen dank für den Exkurs in atomare Interrupt Behandlung =)
