I want to make sound with DE2 and Verilog HELP ME
OP #1988509
• ▲ useful
▼ not useful
Hi guys !
I have a school project with DE2 board & Verilog code, and we're going
to make something like a sound generating machine. It is kind of JUKE
BOX.
First of all, I want to make single tone sound, like beep sound.
For Example, when I push KEY 1 , DE2 board sounds (like beep!)
To make this function, how can I get some information?
Any body Help me Plz !
#1988661
• ▲ useful
▼ not useful
For Altera FPGA take a look at the alteraforum:
http://www.alteraforum.com/forum/
you can search for example for "DE2 audio codec"
I have the DE1 board. There is a book about these boards:
ISBN 9780387726700
take a look inside at google books:
http://books.google.com/books?id=gTMkiCUz11AC&dq=Rapid+prototyping+FPGA&hl=de&source=gbs_navlinks_s
With the DE1 board comes an example project "SD Card Music Player"
"The design uses the Nios II processor to read the music data stored in
the SD Card and uses the Wolfson WM8731 audio CODEC to play the music."
Maybe you can use that code for the audio codec.
Guest #3105481
• ▲ useful
▼ not useful
U R talking about the DE2-115 with a Cyclone chip?
> It is kind of JUKE BOX.
Should be a long way to create a juke box by starting with a simple beep
sound. Are you familiar with sound processing already?
At our university, with have initiated a number of interesting projects,
dealing with sound synthesis with FPGAs. You might get inspired here:
http://ems.eit.uni-kl.de/index.php?id=113&tx_uniklwehn2_pi1%5BshowUid%5D=273&cHash=838a4296a6a43e68415bef03d91469c2
Another project ist described here:
http://www.hs-augsburg.de/~tspanrun/fpgasynth_ausarbeitung.pdf
What I like most is this here:
http://www.youtube.com/watch?v=FgOSa4bLtFY
A professional description can be found here:
http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=628683&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D628683
Guest #3112844
• ▲ useful
▼ not useful
This is an european forum and here, most of the guys work with VHDL. I
personally never used Verilog so I cannot help. But I have managed to
create a little sound engine myself, it can play chords from a small
table instatiated in a BRAM.
What you basically need:
- a BRAM with the key notes
- a transformation table with the frequencies
- a state machine which can collect data from those tables and trigger
- a sound module which switches on and off the notes
The sound engine can be a little pulse width modulation machine,
basically a counter which runs up to the programed frequency
Sounds nice, what is the purpose of this? Do you do research on sound
systems there? What is the FPGA used for? From the website I read, you
are having a complete MIDI synthesizer built in VHDL by your students?
Guest #3116742
• ▲ useful
▼ not useful
Mr Aiko Yuri does not seem to participate anymore - as usual, when
people ask for help in forums: Most of them never return.
Coming to the question: I have an educational Altera DE-115 and also
mangaged to get some noise out of it. Altera offers a complete music
station as demo for the board, moreover there are a number of synth
projects in the Internet, like WWW.FPGA-SYNTH.
 - should be a good starting point.
I played with tha NIOS type musc engine but found it complicating and
area intensive.
My question would be who likes to share some code for easy music with
DE?
Anybody managed to play some mp3s through it?
Guest #3127509
• ▲ useful
▼ not useful
you may want to have a look at the altera forum. there are some topics
how to make sound with this board
> and area intensive.
The NIOS, or it's program?
Guest #3172046
• ▲ useful
▼ not useful
> and area intensive.
both, the NIOS does not require much space, but is not a dedicated Music
engine, so the code is complex
also it should be a prob to achive enough voices by instatiating just
one NIOS, to come to a serious Music application
Guest #3172736
• ▲ useful
▼ not useful
Can somebody of you please give an example for the size of a NIOS system
for signal processing applications like these? It does not need to be
music, but this was fine, though. I know about the NIOS itself beeing
quiet tiny, but there is more to a signal conditioning system than only
the NIOS core. I expect that all finally being much bigger after all,
including IO, user interface and processing stages.
For audio, I guess one can store total wave forms in the external RAM
and use them as samplers. The NIOS should be quick enough, right? Did
anybody do this already?
I require something like a wave playback tool like that, only a bit
higher in range, maybe up to 200kHz frequency. Should the NIOS be able
to do this on a common slow FPGA?
Next to wave generation, I also need some filtering to modify the
waveform and perform a soft fade in and fade out. (the waves control a
sensitive mechanical system)
Guest #3186125
• ▲ useful
▼ not useful
From my knowledge a NIOS circled up to 1E6 times on a Cyclone System
with 50MHz, using non real time OS. Depending on the length of your
operation loop, some 10kHz-100kHz could be operated regularly. Why do
you need a NIOS to press the data? Can't it be done without?
Guest #3450471
• ▲ useful
▼ not useful
to my mind NIOS is not a good idea to produce sound. if one uses a micro
controller, than a real one should be easier to program and to handle
soft cores in fgpas are boring and slow anyway. if they have to deal
with high speed data processing, they will become inefficient quickly
fpgas can perform certain tasks very nice if used the basic way, but for
this target, i recommend a dsp system for signal processing
Guest #3541636
• ▲ useful
▼ not useful
NIOS is not necessary at all. Sound can be produced by simple PWM output
controlled by single values. I would first instantiate a CPU if MUSIC
MIDI processing is required to controll sound from outside.
Guest #3549108
• ▲ useful
▼ not useful
Cxu iu el vi bonvolos doni ekzemplon por la grandeco de NIOS sistemo por
signali prilaborado aplikoj kiel cxi tiuj? Ĝi ne bezonas esti muziko,
sed ĉi tiu estis bona, tamen. Mi scias pri la NIOS mem beeing kvieta
eta, sed estas pli por signali kondiĉado sistemo ol nur la NIOS kerno.
Mi atendus ke ĉiuj fine estante multe pli granda post ĉiuj, inkludante
IO, uzula interfaco kaj prilaborado etapoj.Por sondosieroj, mi supozas
oni povas stoki tutan ondo formoj en la ekstera memoro RAM kaj uzi ilin
kiel samplers. La NIOS devus rapidu sufiĉas, ĉu ne? Did iu faru tion
jam? Apud skuu generacion, mi ankaŭ bezonas iujn filtrilojn por modifi
la ondformo kaj realigi mola fade en kaj fade out. (La ondoj kontroli
sentema mekanika sistemo)
Guest #4091976
• ▲ useful
▼ not useful
I am bachelor of electronics and intend to start to study at KIT. Would
you consider analog or digital music design as an essential subject or
necessary or helpful during studies?
The standard operation plan does not show any of the mentioned projects
so far, but I would be very interested in both learning VHDL and music
development.
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
