Forum: ARM programming with GCC/GNU tools AT91SAM7S256 ~ PORT IO Code Help
Author: Nazmus Sakib (Company: Time & Space) (sakibnaz)
Hello.
I am very new at ARM7. Trying to switch ARM7 from AVR. I am using
WinARM. I have checked the example codes "LED Blink" for both ATMel and
LPC.
for the LPC code (lpc2106_blink_switch )to turn ON a LED:
GPIO_IODIR |= (1<<LEDPIN);  // define LED-Pin as output
GPIO_IOCLR=(1<<LEDPIN);  // set all outputs in mask to 0 -> LED on
I am interested to use ATMel ARM7 AT91SAM7S256 MCU but don't have any
EK.
So, initially I want to write a code which will simple makes a PIN high
logic to turn ON a LED. I want to do this like the LPC code without
adding any board header. Like, there will be a simple mail program which
will define the Output PORT and make a PIN high logic of AT91SAM7S256.
But all ATMel ARM7 example are for the EK. Could anyone suggest to write
the main function to make a PIN high logic without adding ant board
header? Actually after doing some initial code I'll make a breakout for
AT91SAM7S256 chip and try to burn the HEX directly (without EK). Thanks
in advance.
Regards.
Sakibnaz.
Author: Peter (Guest)
Hello,
I do something like:
#define LED1    BIT17
AT91C_BASE_PIOA->PIO_OER = LED1; // Set as Output
p_pPio->PIO_CODR = LED1; // Low
p_pPio->PIO_SODR = LED1; // High
... should not be very tricky, to find out the adresses with the
datasheet.
Kind regards,
Peter
ps.: I´m using the Olimex AT91SAM7P256 with the AT91SAM7S256 on it.
Hello Peter.
Thank you for your reply. Yes I have done the initial port IO Led
Blinking code. Actually I am very beginner on ARM. Now checking the
codes of UART. I am using Keil MDK uVision IDE. What Compiler and IDE
you are using to program your Olimex-EK?
Regards.
Sakibnaz.
Author: Big Wall (tylr2005)
Hello Nazmus.
I'm a beginner on ARM too. I use at91sam7xxxx in my board and develop
with IAR EWARM.
I hope you can understand my words, because my English is so poor.
Regards.
Bigwall.(from China)
Hello Bigwall.
Are you using AT91SAM7X-EK? I don't have the EK yet. I use Keil MDK IDE.
Regards.
Sakibnaz.
Nazmus Sakib wrote:
> Hello Bigwall.
> Regards.
> Sakibnaz.
I'm not use AT91SAM7X-EK. At first I bought a simple board with
AT91SAM7S64 from "www.taobao.com" to study ARM. Then I drawn a pcb with
AT91SAM7X256. The difference between 7S?? and 7X?? are only the Ethernet
peripheral. But the AT91SAM7S64 study board is cheap.   :p
I never use Keil MDK IDE. I always use IAR EWARM. Once I tried YAGARTO
toolchains, but I feel too difficult. In addition, the EWARM's simulator
function is powerful, it can simulate interrupts.
If I have more time, I want to study YAGARTO toolchain. Because it's
free and my EWARM is [...(*)].
Regards.
Bigwall.
[(*) removed by Mod.]
Hello Bigwall.
I never tried IAR. My target is to program AT91SAM7x256 Chip directly. I
have only the Chip. I'll make a breakout board for the Chip. Do you
think, is it possible to program the ARM7 chip directly as like we did
for AVR (using USB, Serial or Parallel port)?
Yes, I also like Open Source projects. I see YAGARTO and there are some
tutorials for YAGARTO and Eclipse by Jim Lynch. Nice tutorial. But I did
not test that yet. It will be a nice learning for me too :-)
Did you see WinARM? Its a nice Open Source Project too. There are lots
of examples by Martin Thomas for AT91SAM7 Series MCU.
Thank you.
Regards.
Sakibnaz.
Hello Sakibnaz.
Your target is feasible.
The at91sam7x and at91sam7s series both have a internal boot program. It
is actived by pull-up the TST pin about 10s when power on.
And Atmel provide a GUI program run in Windows namely SAM-BA. Then you
can program the chip by USB or serial port or J-Link. I hope it is what
you want.  ^_^
And thank you for introduce the WinARM to me, It will be a nice learning
for me too.
If you like, I hope you write e-mail to me anytime. And I'm very glad to
make friend with you. My e-mail is tylr2005@126.com.
Work happily! Now I wish you have a good dream.   :p
Regards.
Bigwall.
Thank you. I appreciate. We can work together in the world of ARM7.
Regards.
Sakibnaz.
