Hi guy's I have the following problem. I'm using the STM32F103RB and Sourcery G++ Lite 2008q1-126 and I try to implement the Interrupt Handlers in a C++ File. I'm using C and C++ Code in my project and if I implement the handlers in a C File everything is working fine, when I get an Interrupt the handler is getting called. But when I want to do the same with an C++ File the handler is not getting called. Anyone out there with some suggestions? Thx
Try to enclose your handler in an extern "C" block to shut down name
mangling for that function.
extern "C"
your interrupt handler goes here, just as you would write it
in C
I tried that an I got the following error message:
error: expected unqualified-id at end of input
#ifndef TIMEMANGER_H_
#define TIMEMANGER_H_
template <typename _GlobalTimeType = unsigned long>
class TimeManager
private:
_GlobalTimeType m_CurrentSuperloopTime;
int x;
public:
TimeManager()
m_CurrentSuperloopTime = 0;
extern "C"
void TIM2_IRQHandler()
x = 1;
#endif /* TIMEMANGER_H_ */
Well. An Interrupt Handler cannot be part of an object. Just as a quick thought: What is the object, the handler gets called for?You don't have one resp. nobody knows but you. An Interrupt Handler is always a freestanding function and you need to route the execution to an object by yourself, since only you, the programmer, know what object should be used for eventually handeling the interrupt.
You cannot do that as part of a class. I don't know the STM32, but my guess is that interrupt vectors are known by their global name, so they cannot be established using C++ name mangling. This also implies they cannot be hidden with in a class (class members don't establish a global name).
So that means an ISR can't be implemented in a Class and I have to do it in a function outside a Class right?
Kenan Özdemir wrote: > So that means an ISR can't be implemented in a Class and I have to do it > in a function outside a Class right? Exactly. But of course nobody is hindering you in calling a member function of an object from the interrupt handler function.
1 | template <typename _GlobalTimeType = unsigned long> |
2 | class TimeManager |
3 | {
4 | private:
5 | _GlobalTimeType m_CurrentSuperloopTime; |
6 | int x; |
7 | public:
8 | TimeManager() |
9 | {
10 | m_CurrentSuperloopTime = 0; |
11 | }
12 | |
13 | void TimeTick() |
14 | {
15 | x = 1; |
16 | }
17 | |
18 | };
19 | |
20 | TimeManager theOneAndOnlyTimerManager; |
21 | |
22 | extern "C" |
23 | {
24 | void TIM2_IRQHandler() |
25 | {
26 | theOneAndOnlyTimerManager.TimeTick(); |
27 | }
28 | }
escamoteur wrote: > It should be possible as a class static function. I haven't tried it, but i don't think it will work. Name mangling gets in your way and you can't get rid of it with a static member function.
I'm back with another question.
I have my main.cpp where i create an object of TimeManager. To use
TIM2_IRQHandler it must be a static function. But when I try to access
the static variable of TimeManager over TimeTick I get an error message:
main.o: In function `TimeManager<unsigned long>::TimeTick()':
...SourceCodes/TimeManager.h:196: undefined reference to
`TimeManager<unsigned long>::var'
class TimeManager
private:
static int var;
public:
TimeManager(){}
static void TimeTick()
var++;
extern "C"
static void TIM2_IRQHandler()
TimerManager<>::TimeTick();
I also tried it with a static class function but it doesn't worked
The right answer was given above... the IRQ_Handler must be a static member of the class. Also, If any class variables are accessed inside this static ISR then they also need to be static. Stick to this and all will be good. A class is just a namespace.
> The right answer was given above... the IRQ_Handler must be a static > member of the class. No. Aan interrupt handler must be extern "C", and that is only possible for non-member functions. The actual problem is that the variable is only declared, but not defined anywhere.
I have this style of code everywhere. I compile with yagarto.
class C_ADC {
public:
C_ADC(){}
virtual ~C_ADC();
void Init(uint32_t ADC_Clk = DEF_ADC_CLK);
private:
static void IRQ_Handler();
irq void C_ADC::IRQ_Handler()
void C_ADC::Init(uint32_t ADC_Clk)
installVector(VIC_CH18_ADC0, (pfunction_t)&C_ADC::IRQ_Handler, 0);
>>I have my main.cpp where i create an object of TimeManager. To use >>TIM2_IRQHandler it must be a static function. But when I try to access >>the static variable of TimeManager over TimeTick I get an error message: >>main.o: In function `TimeManager<unsigned long>::TimeTick()': >>...SourceCodes/TimeManager.h:196: undefined reference to >>`TimeManager<unsigned long>::var' >The actual problem is that the variable is only declared, but not >defined anywhere. Yes -- this is the answer to the above. But that is a problem unrelated to the IRQ handler being in the class, as the error would show for all uninitialized static variables.
