Forum: ARM programming with GCC/GNU tools GCC build directory structure
Author: coolfix (Guest)
Hi, everyone
I'm just getting started using gcc toolchain from yagarto package. I
like to how the build directory structure is organized. Why there are
mutiple bin|include|lib directories and how do I setup my include path
and lib path?
Please help
coolfix wrote:
> Hi, everyone
Some of them are created during the build of the compiler itself and
some are created during build of the libc. Usually there is no need to
worry about this. The compiler/linker will search all needed directories
> and lib path?
This is not needed at all. The search-directories are already set-up
internally. Just make sure to use the front-end (arm-*-gcc) for linking
and do not call the linker (arm-*-ld) directly and everything will work
out.
Thank you for your clarification.
