Forum: ARM programming with GCC/GNU tools Easy (I hope) C const pointer question
Author: jrmymllr jrmymllr (jrmymllr)
I have this array:
const unsigned char *param_tag[]=
  "SMSH=",
  "SMIN=",
  "SMUS=",
  "SMPA=",
  "SMDO=",
  "SYIP=",
  "SYNE=",
  "SYGA=",
  "SYDN=",
  "SYIM="
I had thought that the const would put everything into Flash, however
according to the .map file it appears that the strings are in Flash, but
the pointers to each of the 10 strings are being placed into RAM.  It's
using 40 bytes of RAM: 32 bit micro, 4bytes * 10 strings = 40.
How do I put everything into Flash?  I'm not even sure what to search
for to answer this myself.  My guess is the answer is easy if you know!
Author: A. K. (prx)
A pointer to a constant ist not a constant pointer.
const unsigned char *const param_tag[] = ...
Great, that fixed it!
Author: Rolf Magnus (Guest)
> I have this array:
  "SMSH=",
  "SMIN=",
  "SMUS=",
  "SMPA=",
  "SMDO=",
  "SYIP=",
  "SYNE=",
  "SYGA=",
  "SYDN=",
  "SYIM="
Do you actually need the pointers? If all arrays are the same size, you
can also make it an array of arrays and save the pointers.
const unsigned char param_tag[][6]=
  "SMSH=",
  "SMIN=",
  "SMUS=",
  "SMPA=",
  "SMDO=",
  "SYIP=",
  "SYNE=",
  "SYGA=",
  "SYDN=",
  "SYIM="
Btw: Why unsigned char? There is no such thing as signedness for
characters, so if those are strings, the element type should be char.
That's true.  I have another array similar to this one, but the strings
are different sizes, so I sort of copied and pasted and modified.  But
good point.
The only answer I can give is because I'm a novice :)
I've occasionally wondered about this but just kept going as long as it
worked and I had no warnings.  After initially shunning C, I decided to
teach it to myself and have learned the hard way.  I was one of those in
college who said "I don't want to do any programming".  Now I use all of
it for hobbies and none for my real job.
