Forum: ARM programming with GCC/GNU tools Build Nut/OS application httpd `.ramfunc' error
Author: C k Lui (bcck)
Can anyone know how to fix the error?
Hi there,
I tried to build Nut/OS application httpd with Yagarto and got the build
error below. Does anyone know how to fix it?
Thanks.
**** Build of configuration Default for project httpd ****
make all
arm-elf-gcc -c -mcpu=arm7tdmi -O0 -gdwarf-2 -mthumb-interwork
-fomit-frame-pointer -Wall -Wstrict-prototypes -fverbose-asm
-Wa,-ahlms=src/httpserv.lst -DETHERNUT3   -MD -MP -MF .dep/httpserv.o.d
-I . -ID:/Project/ethernut-4.6.4/nutbld-arm-gccdbg/include
-ID:/Project/ethernut-4.6.4/nut/include -I./inc src/httpserv.c -o
src/httpserv.o
-Wa,-ahlms=src/urom.lst -DETHERNUT3   -MD -MP -MF .dep/urom.o.d -I .
-ID:/Project/ethernut-4.6.4/nut/include -I./inc src/urom.c -o src/urom.o
arm-elf-gcc  ./src/httpserv.o ./src/urom.o -mcpu=arm7tdmi -nostartfiles
-TD:/Project/ethernut-4.6.4/nut/arch/arm/ldscripts/at91_ram.ld
-Wl,-Map=httpserv.map,--cref,--no-warn-mismatch
-LD:/Project/ethernut-4.6.4/nutbld-arm-gccdbg/lib
D:/Project/ethernut-4.6.4/nutbld-arm-gccdbg/lib/nutinit.o
-Wl,--start-group -lnutpro -lnutos -lnutarch -lnutdev -lnutnet -lnutfs
-lnutcrt -Wl,--end-group  -o httpserv.elf
c:/program
files/yagarto/bin/../lib/gcc/arm-elf/4.3.2/../../../../arm-elf/bin/ld.ex
e:
error: no memory region specified for loadable section `.ramfunc'
make: *** [httpserv.elf] Error 1
Are there entries for .ramfunc c-sections in the linker-script?
I cannot find any .ramfunc in the linker-script. How do I add it into
the script?
> the script?
Add a line *(.ramfunc*) near *(.data)
>> the script?
I made the change as below and the linker works. Thanks.
  .data :
    PROVIDE (__data_start = .);
    *(.data)
  *(.data.*)
    *(.gnu.linkonce.d*)
  SORT(CONSTRUCTORS) /* this entry is in the Anglia example */
    /* CONSTRUCTORS */ /* this entry is in the devkitarm script but not
    . = ALIGN(4);
  *(.ramfunc*)
Author: snip (Guest)
looks like you are adding the ramfunc to data!
You should create a separate section for it and locate it in the RAM,
otherwise there is no point in using that attribute.
Also, you placed it before the .ALIGN part. This means that your data
section is no longer aligned on a 32bit boundary. This can be dangerous.
At least add a ". = ALIGN(4);" afterwards as well.
snip wrote:
Please note that this thread is rather old and somehow closed by the OP
with "works".
You seem to confuse input-section(s) for data and the output-section
data.
The output-section .data gets located in RAM (there is not much sense in
locating data in a RO-memory).
This method saves an additional copy-loop since the initial values of
the data-input-sections get copied anyway in the startup. The
machine-code of the RAM-functions can be copied in the same loop from
the non-volatile memory into RAM.
So far it's a little difficult to find the point in the remark.
In the above code-snippet the line for ramfunc input-section(s) is after
the align-instruction.
Yes, alignment can be critical but the linker and compiler "know" some
restictions (AFAIK, I have done just a few tests). Since the lines above
do not show a complete linker-script it's impossible to tell if an
alignment instruction follows. Maybe it's in the next line not shown or
maybe the defintion of output-section .bss with an extra aligment
follows.
