Linker error, undefined reference to `_sbrk'
OP #1173920
• ▲ useful
▼ not useful
I'm trying to compile an MP3 decoder (Helix) with CodeSourcery for ARM
Cortex-M3, and can't shake this error:
arm-none-eabi/lib/thumb2\libc.a(lib_a-sbrkr.o): In function `_sbrk_r':
sbrkr.c:(.text+0xc): undefined reference to `_sbrk'
I've spent hours searching the Internet for info on the error, and hours
fiddling with things trying to fix it.  I can compile a simple LED blink
program.  I believe this error is related to "syscall", but I don't
understand what I need to do to fix it.  Wouldn't this be handled by the
compiler?  If not, would it be possible that the micro vendor (Luminary)
provides a library with the missing piece?  I'd gladly read a small book
to resolve this problem, but don't know what or where to look for it.
Moderator #1173921
• ▲ useful
▼ not useful
The fix is to provide the requested function _sbrk.
> Wouldn't this be handled by the compiler?
No, it's not related to the compiler but to the libc (=newlib). I expect
the MP3-decoder source from the Helix community uses malloc. It seem
that in the CS newlib configuration malloc calls the reentrant version
of _sbrk_r which is already in libc.a and _sbrk_r calls _sbrk which has
to be provided.
Sure, they could add this to the driver-library. But it's not that
difficult to add it yourself.
> I'd gladly read a small book to resolve this problem, but don't know
(1) I expect you are using the linker-script form the Luminary
Driver-Library (standalone.ld). Modify this script a little bit:
.bss :
  _bss = .;
  *(.bss*)
  *(COMMON)
  _ebss = .;
  . = ALIGN (8);
  _end = .;
} > SRAM
PROVIDE(__HEAP_START = _end );
(2) create a file syscalls.c and add the following code:
/* based on a example-code from Keil for CS G++ */
/* for caddr_t (typedef char * caddr_t;) */
#include <sys/types.h>
extern int  __HEAP_START;
caddr_t _sbrk ( int incr )
  static unsigned char *heap = NULL;
  unsigned char *prev_heap;
  if (heap == NULL) {
    heap = (unsigned char *)&__HEAP_START;
  prev_heap = heap;
  /* check removed to show basic approach */
  heap += incr;
  return (caddr_t) prev_heap;
(3) make sure the file is compiled and the object-code from it gets
linked
This should get you started (not tested here). You can add additional
"out of heap-space" checks later if needed.
Hope this helps.
EDIT: added include
OP #1173922
• ▲ useful
▼ not useful
> Hope this helps.
> EDIT: added include
Thank you!  I initially tried to get it to compile, but that was without
the include.  I didn't spend much extra time on it until now.  It's
compiling....now I have a place to start.
A question of your own? This thread is over 18 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
