AVB media clock synchronization for audio
OP Admin #3424598
All devices on an AVB network have a clock which is automatically
synchronized using the Precision Time Protocol (PTP). However, this does
not mean that every AVB talker on the network automatically uses a
synchronized sampling rate for the audio stream it sends ("Media Clock")
[1]. For example, one device might generate an 48 kHz media clock with
an external oscillator; another device might derive an 48 kHz media
clock from its PTP clock; yet another device might synchronize to an
ADAT lightpipe input; etc. While these sampling rates are nominally the
same, the clocks are not synchronized.
To generate AVB streams with synchronized media clocks in multiple
devices, a media clock has to be generated in one device and distributed
to the others. At the moment, the only way to distribute a media clock
is to act as a talker and provide a stream (which does not neet to
contain any actual audio channels) to other devices, which may then
recover the media clock from this stream and generate their own talker
stream with the same media clock. In the XMOS AVB reference
implementation, if an input stream is connected to the listener, the
media clock is automatically recovered from this stream and used for the
talker [2].
For IEEE1722a a stream format for the distribution of a global media
clock has been proposed [3].
[1] Understanding IEEE's deterministic AV bridging standards,
http://www.embedded.com/print/4008284
[2] XMOS AVB Media Clocks, http://xcore.github.io/sw_avb/clocking.html
[3] 1722A Global System Clock Streams (aka Media Clock Streams),
http://grouper.ieee.org/groups/1722/contributions/2013/1722a_rsilfvast_Global-System-Clock-Stream-Principles_15-Apr-2013.pdf
Guest #3503328
http://www.avnu.org/files/static_page_files/C5E0B5F8-1D09-3519-ADB32F1F88E6C057/AVnu_SWAPIs_v1.0.pdf
contains more information about best practices for media clock handling.
"Many real world applications (a mixer for example) require a Listener
to receive audio from multiple Talkers (many microphones for example).
In these situations, a common media clock for all Talkers eliminates the
need for sample rate conversion (SRC) operations inside the Listener.
The implication is that some sort of “House Media Clock” equivalent for
AVB is required. Although not formally part of the AVB specification
suite, the simplest method of distributing a “House Media Clock” is via
a designated AVB stream that contains the canonical media clocking
information - any stream can be designated as the house clock reference
stream. Any Talker device that can talk to a mixing device should also
be capable of being a Listener so that it can Listen to “House Media
Clock” AVTP packets and adjust its internal media clock to match the
“House Media Clock”."
A question of your own? This thread is over 12 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
Formatting
  • [c]C-Code[/c]
More about formatting
Already registered? Log in
