I'm currently exploring the potential of integrating embedded FPGAs (eFPGA) into modern embedded systems. Given their reconfigurability and adaptability, eFPGAs seem like a promising solution for enhancing system flexibility and performance. However, I'm curious about the practical challenges and benefits of incorporating eFPGA into embedded designs. For instance, how does the inclusion of eFPGA compare with traditional ASIC or microcontroller approaches in terms of power consumption, cost, and development time? Additionally, what are the current limitations of eFPGA technology that developers should be aware of? I'm also interested in hearing about any specific use cases where eFPGAs have proven to be particularly advantageous. Whether it’s for custom data processing, offloading tasks from the main processor, or adapting to changing standards, I'm keen to learn more from those who have hands-on experience with this technology. https://www.icdrex.com/what-is-embedded-fpga-efpga/
You just want to promote your site and spread your opinion and have no idea what FPGAs are. An "embedded" FPGA is nothing more than programmable logic integrated into a so-called system on a chip. This allows the FPGA to be used in just as many applications and offer better performance, flexibility and versatility as the normal one. There is no differenc. In the opposite: By using an FPGA within an SoC, the size and cost of the device can be not allways reduced and also the performance is not automatically improved, because of power dissipation issues and more. The FPGA can not as easily be programmed to implement user-defined logic functions, and it can has problems be used as an interface to other chips, because mostly they are not on the SoC but have to be additionally placesd! One of the supposed main advantages of an embedded FPGA, its flexibility, is also very relative! While integrating the FPGA into an SoC theoretically reduces the size and cost of the device and allows new functions to be added quickly and easily without having to redesign the entire system, this is just as true of the normal FPGA! This is because it can also be programmed to implement user-defined logic functions and be used as an interface to other chips, which are usually not on the SoC as said. In this way, complex systems can theoretically be realized on a single chip, but this does not really reduce costs if the individual parts are cheaper. The supposed advantage of these "FPGAs", this site is proclaming inamely the ability to be reconfigured during operation, is much easier with external components. Non-embedded FPGAs therefore often enable faster prototyping, as the FPGA can be quickly and easily swapped to implement more logic functions than originally planned. This is not possible with a finished SOC! In this way, new designs are quickly written in record time, but not developed faster and not tested at all, which can significantly increase the time and cost of design and development. This so far!
