Forum: PC-Programmierung Brauche Hilfe in javascript programmierung
von Martin L. (tempusertempuser)
ich habe ein Digitales Messgeraet welches folgendes Json ausgibt
{"1":[{"a":"19:10","b":"20:30","c":"1"},{"a":"12:30","b":"13:40","c":3}],"2":[{"a":"14:10","b":"15:30","c":"2"},{"a":"9:30","b":"10:00","c":"3"}],"3":[{"a":"8:10","b":"8:20","c":"4"},{"a":"7:10","b":"7:20","c":"3"}],"4":[{"a":"8:10","b":"8:20","c":"5"},{"a":"6:20","b":"6:30","c":"f"}]}
Ist es moeglich mit javascript folgende Tabelle daraus einfach zu
generieren?
<style type="text/css">
.tg  {border-collapse:collapse;border-spacing:0;}
.tg td{font-family:Arial, sans-serif;font-size:14px;padding:10px 5px;border-style:solid;border-width:1px;overflow:hidden;word-break:normal;}
.tg th{font-family:Arial, sans-serif;font-size:14px;font-weight:normal;padding:10px 5px;border-style:solid;border-width:1px;overflow:hidden;word-break:normal;}
</style>
<table class="tg">
  <tr>
    <th class="tg-031e">a</th>
    <th class="tg-031e">b</th>
    <th class="tg-031e">c</th>
    <th class="tg-031e">d</th>
    <th class="tg-031e"></th>
  </tr>
  <tr>
    <td class="tg-031e" rowspan="2">1</td>
    <td class="tg-031e">19:10</td>
    <td class="tg-031e">20:30</td>
    <td class="tg-031e">1</td>
    <td class="tg-031e"></td>
  </tr>
  <tr>
    <td class="tg-031e">12:30</td>
    <td class="tg-031e">13:40</td>
    <td class="tg-031e">3</td>
  </tr>
  <tr>
    <td class="tg-031e" rowspan="2">2</td>
    <td class="tg-031e">14:10</td>
30
    <td class="tg-031e">15:30</td>
31
    <td class="tg-031e">2</td>
32
33
  </tr>
34
  <tr>
35
    <td class="tg-031e">9:30</td>
36
    <td class="tg-031e">10:00</td>
37
38
39
  </tr>
40
  <tr>
41
    <td class="tg-031e" rowspan="2">3</td>
42
    <td class="tg-031e">8:10</td>
43
    <td class="tg-031e">8:20</td>
44
    <td class="tg-031e">4</td>
45
46
  </tr>
47
  <tr>
48
    <td class="tg-031e">7:10</td>
49
    <td class="tg-031e">7:20</td>
50
51
52
  </tr>
53
  <tr>
54
    <td class="tg-031e" rowspan="2">4</td>
55
56
57
    <td class="tg-031e">5</td>
58
59
  </tr>
60
  <tr>
61
    <td class="tg-031e">6:20</td>
62
    <td class="tg-031e">6:30</td>
63
64
65
  </tr>
66
</table>
Danke fuer eure Hilfe ich stehe auf dem Schlauch
von Christoph K. (backdraft007)
Moin,
sehe bisher kein Javascript.
https://www.w3schools.com/js/js_json.asp
https://www.w3schools.com/jsref/jsref_foreach.asp
Mal so als erste Lektüre.
hier ist mein Versuch
let text = '{"1":[{"a":"19:10","b":"20:30","c":"1"},{"a":"12:30","b":"13:40","c":3}],"2":[{"a":"14:10","b":"15:30","c":"2"},{"a":"9:30","b":"10:00","c":"3"}],"3":[{"a":"8:10","b":"8:20","c":"4"},{"a":"7:10","b":"7:20","c":"3"}],"4":[{"a":"8:10","b":"8:20","c":"5"},{"a":"6:20","b":"6:30","c":"f"}]}';
const obj = JSON.parse(text);
alert(obj.1[0].a);
Zeigt nichts an
Martin L. schrieb:
> alert(obj.1[0].a);
Das funktioniert auch nicht.
console.log(obj);
Und dann benutzt Du die Entwickertools Deines Browsers und weiter geht
es.
https://www.w3schools.com/js/js_arrays.asp
von Rolf (rolf22)
> generieren?
Ja, aber nicht "einfach".
Das geht jedenfalls gar nicht. Rechts vom Gleichheitszeichen muss eine
Konstante stehen. Ein Funktionsaufruf ist aber keine Konstante.
Ist da keine Fehlermeldung gekommen? Und warum willst du überhaupt, dass
das Objekt eine Konstante ist?
von Εrnst B. (ernst)
Natürlich geht das. die const-variable wird mit dem
Funktions-Rückgabewert initialisiert, und ist danach unveränderlich.
übrigens nur "obj" selber. Nicht die Objekte, auf die das zeigt.
const obj=JSON.parse(text);
obj["1"][0]["a"]=42;
ist erlaubt.
obj=42;
nicht.
von Daniel A. (daniel-a)
Martin L. schrieb:
> alert(obj.1[0].a);
> Zeigt nichts an
Identifier können nicht mit 1 beginnen, deshalb ist obj.1 ungültig. Der
[] Operator kann sowohl bei Objekten als auch bei Arrays angewendet
werden, wenn ein Objekt Key kein gültiger Identifier ist, kann man damit
trotzdem darauf zugreifen. Hier also `obj[1][0].a` oder
`obj["1"]["0"].a` (kommt aufs selbe raus).
> generieren?
Da gibt es viele varianten. Per DOM (document.createElement(),
element.appendChild(node), element.classList.add("class"), etc.), per
Frameworks, etc.
Bei ganz kleineren Projekten nutze ich oft kleine Template
Hilfsfunktionen: https://jsfiddle.net/Lrjh7kyz/2/
Daniel A. schrieb:
>> generieren?
> Frameworks, etc.
Danke fuer dein Code der sieht echt gut aus...
Ist es eigentlich auch moeglich aus der Tabelle dann wieder ein json zu
erstellen automatisch?
von Heinz B. (Firma: Privat) (hbrill)
Also, beim einfachen Parsen (textfriendly) bekomme ich da
4 Objekte  -> 1 - 4. Und jedes Objekt enthält wiederum eine
Liste mit 2 Objekten, in denen dann a,b,c wieder in einem einzelnen
Objekt definiert sind.
Mit einer Sprache (die auch JSON-Funktionen bereitstellt) deiner Wahl
dürfte es doch einfach sein, die Uhrzeiten durch Iterieren heraus zu
filtern. Ich gehe mal jetzt von deinem angeängten Bild aus.
Das ganze in ein Gitter zu schreiben, ist ja auch kein Problem.
Da könnte man sogar auch ändern und erneut speichern.
Deute ich das so richtig ?
Vielleicht hilft dir schon sowas weiter :
https://www.w3schools.com/js/js_json_html.asp
Außerdem gibt es noch verschiedene Online JSON TO HTML - Konverter.
von Hans (ths23)
> 45alert(obj.1[0].a);
> Zeigt nichts an
So funktioniert das auch nicht. Du mußt die JSON-Daten erst mal
einlesen, bevor Du parsen kannst - eigentlich logisch oder?
Das geht z.B. mit jQuery und der Funktion getJSON(url[, data][,
success]). Bei url gibt man die Datenquelle an. Bei mir ist das ein
PHP-Script welches auf dem Server läuft und die Daten an die Webseite
sendet. success ist die Funktion die ausgeführt wird, wenn der
Datenempfang erfolgreich war. In dieser Funktion werden die Daten dann
auch zur Anzeige gebracht.
Bei mir sieht das in etwa so aus (Auszug aus meiner Webseite):
function readData(){
   $.getJSON(<URL>, setData);
function setData(data){
  var jsonArray = jQuery.parseJSON(data);
      do something with jsonArray
Gute Beispiele, was man nicht machen sollte. XSS, und das total
veraltete XMLHttpRequest...
jQuery ist heute auch nicht mehr empfehlenswert. Für Requests nimmt man
heute das native fetch():
https://developer.mozilla.org/en-US/docs/Web/API/Fetch_API/Using_Fetch
Hier ist meine Version
<!DOCTYPE html>
<html>
<head>
<style>
.tg  {
  border-collapse: collapse;
  border-spacing: 0;
.tg td {
  font-family: Arial, sans-serif;
  font-size: 14px;
  padding: 10px 5px;
  border-style: solid;
  border-width: 1px;
  overflow: hidden;
  word-break: normal;
.tg th {
  font-size: 14px;
  font-weight: normal;
  padding: 10px 5px;
  border-width: 1px;
  overflow: hidden;
  word-break: normal;
30
31
</style>
32
<script>
33
function myFunction() {
34
const answer = [...document.querySelectorAll(".tg>tbody>tr:has(td)")].reduce((acc, row, index, rows) => {
35
  const offset = +(row.cells.length > 4);
36
  const [a, b, c] = [...row.cells].slice(offset).map(({textContent}) => textContent);
37
  const n = rows[index - 1 + offset].cells[0].textContent;
38
  acc[n] = acc[n] || [];
39
  acc[n].push({a, b, c});
40
  return acc
41
42
console.log(answer)
43
44
</script>
45
</html>
46
<body>
47
<button onclick="myFunction()">Click me</button>
48
49
<script>
50
51
// Nützliche Templating Funktionen
52
function html2fragment(html){
53
  const template = document.createElement("template");
54
  template.innerHTML = html;
55
  return template.content;
56
57
58
function TemplateInstance(root){
59
  const result = {};
60
  for(const element of Array.from(root.querySelectorAll('[\\@]'))){
61
    const name = element.getAttribute('@');
62
    element.removeAttribute('@');
63
    result[name] = element;
64
    element.classList.add('at-'+name);
65
66
  result.fragment = root;
67
  return result;
68
69
70
function Template(html){
71
  const fragment = html2fragment(html);
72
  return (d=document)=>TemplateInstance(d.importNode(fragment, true));
73
74
75
// Tabelle aufbauen
76
const T_Table = Template(`
77
  <table class="tg" @="table">
78
    <thead>
79
      <th>a</th>
80
      <th>b</th>
81
      <th>c</th>
82
      <th>d</th>
83
    </thead>
84
  </table>
85
86
87
const T_Row = Template(`
88
  <tr @="tr">
89
    <td class="tg-031e" @="a"></td>
90
    <td class="tg-031e" @="b"></td>
91
    <td class="tg-031e" @="c"></td>
92
  </tr>
93
94
95
const T_GroupCells = Template(`<td @="id" class="tg-031e" rowspan="999999"></td>`);
96
97
98
function dataToTable(data){
99
  const e_table = T_Table();
100
  for(const [id,group] of Object.entries(data)){
101
    const tbody = document.createElement("tbody");
102
    let firstRow = null;
103
    for(const row of group){
104
      const e_row = T_Row();
105
      firstRow ??= e_row;
106
      e_row.a.textContent = row.a;
107
      e_row.b.textContent = row.b;
108
      e_row.c.textContent = row.c;
109
      tbody.appendChild(e_row.fragment);
110
111
    const e_cells = T_GroupCells();
112
    e_cells.id.textContent = id;
113
    // Note, we could get all td in e_cells.fragment and set rowspan to the correct number, it's easier to just put the rows in a tbody and set rowspan to a high number to fill all the rows in the tbody
114
    firstRow.tr.prepend(e_cells.fragment);
115
    e_table.table.appendChild(tbody);
116
117
  return e_table.fragment;
118
119
120
const text = '{"1":[{"a":"19:10","b":"20:30","c":"1"},{"a":"19:10","b":"20:30","c":"1"},{"a":"12:30","b":"13:40","c":3}],"2":[{"a":"14:10","b":"15:30","c":"2"},{"a":"9:30","b":"10:00","c":"3"}],"3":[{"a":"8:10","b":"8:20","c":"4"},{"a":"8:10","b":"8:20","c":"4"},{"a":"7:10","b":"7:20","c":"3"}],"4":[{"a":"8:10","b":"8:20","c":"5"},{"a":"6:20","b":"6:30","c":"f"}]}';
121
const data = JSON.parse(text);
122
123
const e_table = dataToTable(data);
124
125
document.body.appendChild(e_table);
126
127
128
</script>
129
</body>
130
</html>
allerdings erhalte ich einen Fehler
TypeError: Cannot read properties of undefined (reading 'cells') at 'myFunction'
Was mache ich da falsch?
> 'myFunction'
Hier:
verrechnest du dich, und greifst auf eine nicht-existierende Row zu.
Εrnst B. schrieb:
>> 'myFunction'
> Hier:
Wie muss die Zeile dann richtig heißen?
Hängt davon ab, was du da auslesen wolltest.
Ich würde davor eine Zeile einfügen:
  console.log(`Bei Iteration ${index} wird mit Offset ${offset} auf Row ${index - 1 + offset} von ${rows.length} zugegriffen`);
Oder mit dem Debugger dort einen Breakpoint setzen, und die Variablen
anschauen.
> anschauen.
Hallo ich habe nun einen neune versuch gestartet
<!DOCTYPE html>
<html>
<head>
<style>
.tg  {
  border-spacing: 0;
.tg td {
  font-size: 14px;
  padding: 10px 5px;
  border-width: 1px;
  overflow: hidden;
  word-break: normal;
.tg th {
  font-size: 14px;
  padding: 10px 5px;
  border-width: 1px;
  overflow: hidden;
  word-break: normal;
</style>
<script>
30
31
function tableToJson(html) {
32
    // parse html string into dom object
33
    const doc = new DOMParser().parseFromString(html, "text/html");
34
    // extract table node
35
    const table = doc.querySelector("table");
36
    // extract header names from first row. NOTE: map cannot be called on result of querySelectorAll, it has to be converted to an array using spread operator first
37
    const headers = [...table.querySelectorAll("th")].map((h) => h.textContent);
38
    const json = [];
39
    // iterate through rows not containing table headers
40
    table.querySelectorAll("tr:not(:has(th))").forEach((row) => {
41
42
        const item = {};
43
        // check if td needs a new json array item
44
        const spanned = row.querySelector("td[rowspan]");
45
        const rowspan = spanned ? parseInt(spanned.getAttribute("rowspan")) : 0;
46
         console.log(rowspan);
47
        // process all td nodes in row
48
        row.querySelectorAll("td").forEach((td, index) => { if (td.textContent){
49
50
        item[headers[index]] = td.textContent;
51
52
53
54
        // append current item to json array
55
        if (rowspan || json.length === 0) {
56
            // cell is spanned, wrap it in an array under 'json'
57
            json.push([item]);
58
59
        else {
60
            // push item to last array in 'json'
61
            json[json.length - 1].push(item);
62
63
        //console.log(json);
64
65
    return json;
66
67
let ele = document.getElementsByTagName( 'html' );
68
var htmlElements = document.getElementsByTagName('html');
69
//var htmlElements = htmlObject.getElementsByTagName("*");
70
var stringWithHtmlTobeSavedInTextArea="";
71
for (i = 0; i < htmlElements.length ; i++){
72
    stringWithHtmlTobeSavedInTextArea += htmlElements[i].outerHTML;
73
74
console.log(stringWithHtmlTobeSavedInTextArea);
75
const formatted = tableToJson(stringWithHtmlTobeSavedInTextArea);
76
console.log(formatted);
77
78
</script>
79
</html>
80
<body>
81
82
<script>
83
84
85
86
87
88
89
90
  const result = {};
91
92
93
94
95
96
97
98
  return result;
99
100
101
102
103
104
// Tabelle aufbauen
105
106
107
    <thead>
108
      <th>a</th>
109
      <th>b</th>
110
      <th>c</th>
111
      <th>d</th>
112
    </thead>
113
  </table>
114
115
116
  <tr @="tr">
117
118
119
120
  </tr>
121
122
123
124
125
126
127
128
129
130
      firstRow ??= e_row;
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
</script>
149
</body>
150
</html>
allerdings gibt er mir nun folgendes aus
[[{"a":"1","b":"19:10","c":"20:30","d":"1"},{"a":"19:10","b":"20:30","c":"1"},{"a":"12:30","b":"13:40","c":"3"}],[{"a":"2","b":"14:10","c":"15:30","d":"2"},{"a":"9:30","b":"10:00","c":"3"}],[{"a":"3","b":"8:10","c":"8:20","d":"4"},{"a":"8:10","b":"8:20","c":"4"},{"a":"7:10","b":"7:20","c":"3"}],[{"a":"4","b":"8:10","c":"8:20","d":"5"},{"a":"6:20","b":"6:30","c":"f"}]]
