Forum: PC-Programmierung init.lua nvim probleme
von Chandler B. (chandler)
ich habe nVim auf Windows am laufen und habe probleme beim ausführen von
init.lua
ich habe die Plugins
Plug 'giusgad/pets.nvim' | Plug 'MunifTanjim/nui.nvim' | Plug 'edluffy/hologram.nvim'
installiert
in meiner init.vim habe ich ganz am ende
lua require('init')
in dieser Datei steht
require'pets'.setup({
  row = 1, -- the row (height) to display the pet at (higher row means the pet is lower on the screen), must be 1<=row<=10
  col = 0, -- the column to display the pet at (set to high number to have it stay still on the right side)
  speed_multiplier = 1, -- you can make your pet move faster/slower. If slower the animation will have lower fps.
  default_pet = "dog", -- the pet to use for the PetNew command
  default_style = "brown", -- the style of the pet to use for the PetNew command
  random = true, -- whether to use a random pet for the PetNew command, overrides default_pet and default_style
  death_animation = true, -- animate the pet's death, set to false to feel less guilt -- currently no animations are available
  popup = { -- popup options, try changing these if you see a rectangle around the pets
    width = "30%", -- can be a string with percentage like "45%" or a number of columns like 45
    winblend = 100, -- winblend value - see :h 'winblend' - only used if avoid_statusline is false
    hl = { Normal = "Normal" }, -- hl is only set if avoid_statusline is true, you can put any hl group instead of "Normal"
    avoid_statusline = false, -- if winblend is 100 then the popup is invisible and covers the statusline, if that
    -- doesn't work for you then set this to true and the popup will use hl and will be spawned above the statusline (hopefully)
Wenn ich jetzt jedoch meine init.vim neu lade, bekomme ich den Fehler
E5108: Error executing lua [string ":lua":1: loop or previous error loading module 'init'
stack traceback:
[C]: in function 'require'
[string] ":lua"}:1: in main chunk
Bzw. eigentlich ist das lua nicht wirklich das Problem.
Das Problem ist mehr, dass obwohl die Plugins installiert sind, die
Befehle nicht bekannt sind.
Da stand auf https://github.com/giusgad/pets.nvim nur, dass anschließen
require("pets").setup({
  -- your options here
} aufgerufen werden muss.
