Humidity Sensor with DHT11 and PIC16F676
OP #7632477
Hello Guys
I am trying to develop a humidity sensor with DHT11 for my bathroom. The DHT11 Sensor reads the humidity and sends it to the PIC, if the humidity is over 75% a LED should light up. If its under 75% the LED is off.
But I have two problems.
First of all I am programming the PIC16F676 with a PICKIT3 clone - and when trying to debug my code the following error appears in MPLAB (1) Error when trying to debug: )
But now to my project:
If I upload (2)code without error-search), nothing really happens with the LED, when the humidity rises. Even if I change line 46 to "if ( int_RH > 0 )". This is probably the case because line 46 never happens. Thats because result isn't eaqual to 0.
So i tried to find out, where in the function "uint8_t Read_DHT ( uint8_t *data )" the problem happens.
And after changing the code to (3) Code with error-search) i found out, that the problem is due to the timeout in line 118
    uint16_t timeout = 10000;
    while ( SENSOR == 1 )
        if ( --timeout == 0 )
            return 0x0F;
Interesting: If I upload the same code to a programming board with the PIC18F45K22 and add the DHT11 Sensor, everything works as it should. Sadly I am not able to use this programming board for my project. Therefore I would like to do it with the PIC16F676.
Have you guys any idea, how i can fix this problem?
If you need to know anything about the circuit, I added the schmetic to the attachment.
  • I am new to the forum therefore I apologise if I forgot to add something you should know.
  1. Error when trying to debug:
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make  -f nbproject/Makefile-default.mk dist/default/debug/test.X.debug.elf
make[2]: Entering directory 'C:/Users/domin/Desktop/ueK_6/test.X'
"C:\Program Files\Microchip\xc8\v2.46\bin\xc8-cc.exe"  -mcpu=16F676 -c  -D__DEBUG=1  -mdebugger=pickit3   -mdfp="C:/Program Files/Microchip/MPLABX/v6.20/packs/Microchip/PIC16Fxxx_DFP/1.6.156/xc8"  -fno-short-double -fno-short-float -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-2 -Wa,-a -DXPRJ_default=default  -msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -mdefault-config-bits   -std=c99 -gdwarf-3 -mstack=compiled:auto:auto     -o build/default/debug/main.p1 main.c
::: advisory: (2100) using the C99 standard library with the selected device may result in larger code and data usage
make[2]: Leaving directory 'C:/Users/domin/Desktop/ueK_6/test.X'
"C:\Program Files\Microchip\xc8\v2.46\bin\xc8-cc.exe"  -mcpu=16F676 -c  -D__DEBUG=1  -mdebugger=pickit3   -mdfp="C:/Program Files/Microchip/MPLABX/v6.20/packs/Microchip/PIC16Fxxx_DFP/1.6.156/xc8"  -fno-short-double -fno-short-float -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-2 -Wa,-a -DXPRJ_default=default  -msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -mdefault-config-bits   -std=c99 -gdwarf-3 -mstack=compiled:auto:auto     -o build/default/debug/configuration_bits.p1 configuration_bits.c
make[2]: *** [nbproject/Makefile-default.mk:143: dist/default/debug/test.X.debug.elf] Error 1
make[1]: *** [nbproject/Makefile-default.mk:85: .build-conf] Error 2
make: *** [nbproject/Makefile-impl.mk:39: .build-impl] Error 2
"C:\Program Files\Microchip\xc8\v2.46\bin\xc8-cc.exe"  -mcpu=16F676 -Wl,-Map=dist/default/debug/test.X.debug.map  -D__DEBUG=1  -mdebugger=pickit3  -DXPRJ_default=default  -Wl,--defsym=__MPLAB_BUILD=1   -mdfp="C:/Program Files/Microchip/MPLABX/v6.20/packs/Microchip/PIC16Fxxx_DFP/1.6.156/xc8"  -fno-short-double -fno-short-float -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-2 -Wa,-a -msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -mdefault-config-bits -std=c99 -gdwarf-3 -mstack=compiled:auto:auto         -Wl,--memorysummary,dist/default/debug/memoryfile.xml -o dist/default/debug/test.X.debug.elf  build/default/debug/main.p1 build/default/debug/configuration_bits.p1
main.c:177:: error: (800) undefined symbol "btemp"
(908) exit status = 1
BUILD FAILED (exit value 2, total time: 1s)
  1. Code without error-search:
// -- INCLUDES ----------------------------------------------------------------
#include <xc.h>        // Compiler-Include (Port-Defines)
#include <stdbool.h>  // Include for data type 'bool' and keywords 'true' and 'false'
#include <stdint.h>   // Include for defines the standard integer types per ISO/IEC 9899:1999
// -- DEFINES -----------------------------------------------------------------
#define _XTAL_FREQ 10000000 // Crystal oscillator frequencies of 10Mhz
#define LOOP_DELAY 1000  // Loop-Delay in ms
#define WARN_LED PORTCbits.RC2
#define SENSOR PORTAbits.RA2
#define SENSOR_TRIS TRISAbits.TRISA2
// -- FUNCTIONS-PROTOTYPE ----------------------------------------------------
uint8_t Read_DHT ( uint8_t *data );
// -- SETUP -------------------------------------------------------------------
void setup ( void )
    ANSEL = 0x00;
    TRISC = 0x00;
    SENSOR_TRIS = 1;
// -- LOOP ---------------------------------------------------------
30
void loop ( void )
31
32
33
34
    static uint8_t data[5] = { 0 };
35
36
    uint8_t result = Read_DHT( data );
37
38
    if ( result == 0 )
39
40
        uint8_t int_RH = data[0];
41
        uint8_t dec_RH = data[1];
42
        uint8_t int_T = data[2];
43
        uint8_t dec_T = data[3];
44
45
46
        if ( int_RH > 75 )
47
48
            WARN_LED = 1;
49
50
        else
51
52
            WARN_LED = 0;
53
54
55
56
57
// -- main -----------------------------------------------------------
58
59
void main ( void )
60
61
    setup( );
62
63
    // (Loop)
64
    while ( 1 )
65
66
        loop( );
67
        __delay_ms( LOOP_DELAY );
68
69
70
71
// -- FUNCTIONS --------------------------------------------------------------
72
73
74
75
76
77
    // SENSOR as OUTPUT
78
    SENSOR_TRIS = 0;
79
    SENSOR = 0;
80
    //wait 18ms
81
82
    __delay_ms( 18 );
83
84
    SENSOR = 1;
85
86
87
    __delay_us( 40 );
88
89
    // SENSOR as INPUT
90
    SENSOR = 0;
91
92
    SENSOR_TRIS = 1;
93
94
95
96
97
98
99
            return 0x0F;
100
101
102
103
    timeout = 10000;
104
    while ( SENSOR == 0 )
105
106
107
108
            return 0xFF;
109
110
111
112
    timeout = 10000;
113
114
115
116
117
            return 0xFF;
118
119
120
121
    for ( uint8_t i = 0; i < 5; i++ )
122
123
        for ( int8_t j = 7; j >= 0; j-- )
124
125
126
            timeout = 10000;
127
128
129
130
131
                    return 0xFF;
132
133
134
            uint8_t signal_counter = 0;
135
            timeout = 10000;
136
137
138
                signal_counter++;
139
                __delay_us( 1 );
140
                if ( signal_counter > 100 )
141
142
                    return 0xFE;
143
144
145
146
147
148
            if ( signal_counter > 30 )
149
150
                data[i] |= (1 << j);
151
152
153
154
155
    if ( ( uint8_t ) (data[0] + data[1] + data[2] + data[3]) != data[4] )
156
157
        return 0xFF;
158
159
160
    return 0;
161
162
163
  1. Code with error-search
void setup ( void )
    ANSEL = 0x00;
    TRISC = 0x00;
    SENSOR_TRIS = 1;
// --- loop ---------------------------------------------------------
30
void loop ( void )
31
32
33
34
35
36
37
    // Error 1
38
        if ( result == 0xFF )
39
40
            while ( 1 )
41
42
                    WARN_LED = 1;
43
                    __delay_ms( 2000 );
44
                    WARN_LED = 0;
45
                    __delay_ms( 2000 );
46
47
48
49
    // Error 2
50
        if ( result == 0x0F )
51
52
            while ( 1 )
53
54
                    WARN_LED = 1;
55
                    __delay_ms( 200 );
56
                    WARN_LED = 0;
57
                    __delay_ms( 200 );
58
59
60
61
    if ( result == 0 )
62
63
64
65
66
67
68
69
        if ( int_RH > 75 )
70
71
            WARN_LED = 1;
72
73
        else
74
75
            WARN_LED = 0;
76
77
78
79
80
81
82
void main ( void )
83
84
    setup( );
85
86
    // (Loop)
87
    while ( 1 )
88
89
        loop( );
90
91
92
93
94
95
96
97
98
99
100
    // SENSOR as OUTPUT
101
    SENSOR_TRIS = 0;
102
    SENSOR = 0;
103
    //wait 18ms
104
105
    __delay_ms( 18 );
106
107
    SENSOR = 1;
108
109
110
    __delay_us( 40 );
111
112
    // SENSOR as INPUT
113
    SENSOR = 0;
114
115
    SENSOR_TRIS = 1;
116
117
118
119
120
121
122
            return 0x0F;
123
124
125
126
    timeout = 10000;
127
128
129
130
131
            return 0xFF;
132
133
134
135
    timeout = 10000;
136
137
138
139
140
            return 0xFF;
141
142
143
144
145
146
147
148
149
            timeout = 10000;
150
151
152
153
154
                    return 0xFF;
155
156
157
158
            timeout = 10000;
159
160
161
                signal_counter++;
162
                __delay_us( 1 );
163
164
165
                    return 0xFE;
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
        return 0xFF;
181
182
183
    return 0;
184
185
186
A question of your own? This thread is over 2 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
