Serial port disconnects, when programmable power socket is activated
OP #7604528
Hi there :) I´m working on an experiment atm that requires an arduino to listen to key presses ("1" to "7") from my laptop (via CoolTerm Serial Terminal). Furthermore, i also use a programmable power socket, in order to start/power another device when a specific (different) key ("z") is pressed on the keyboard. Both parts work perfectly fine on their own. But when both are being used, the key press that starts the power socket, also leads to CoolTerm disconnecting the serial port, before reconnecting after 2-3 sec. With this delay my experiment unfortunately doesnt work.
Does anyone have an idea where my problem/mistake could be located? I´m very thankful for any help i can get :slight_smile:
this is the short python code, that starts the programmable power socket by running a manufacturer .exe :
import subprocess, keyboard
from pynput.keyboard import Listener
def on_press(key):
    if keyboard.is_pressed('z'):
        subprocess.call(['C:\\Users\\Julius\\USBswitchCmd.exe', '1'])
def on_release(key):
    subprocess.call(['C:\\Users\\Julius\\USBswitchCmd.exe', '0'])
with Listener(on_press=on_press, on_release=on_release) as listener:  # Create an instance of Listener
    listener.join()
and this is the arduino code, that starts a specific servo when a specific key is pressed on the keyboard:
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
int val; // initial value of input
Adafruit_PWMServoDriver myServo = Adafruit_PWMServoDriver();
#define SERVOMIN 150
#define SERVOMAX 600
uint8_t servonum = 0;
uint8_t numberOfServos = 7;
void setup() {
  Serial.begin(9600);
  myServo.begin();
  myServo.setPWMFreq(60);
  delay(10);
  myServo.setPWM(0, 0, 150); // set starting point
  myServo.setPWM(1, 0, 150);
  myServo.setPWM(2, 0, 150);
  myServo.setPWM(3, 0, 150);
  myServo.setPWM(4, 0, 150);
  myServo.setPWM(5, 0, 150);
  myServo.setPWM(6, 0, 150);
void loop() {
30
31
if (Serial.available()) // if serial value is available
32
33
34
    val = Serial.read();// then read the serial value
35
36
    if (val == '1') //if value input is equals to 1
37
38
39
      myServo.setPWM(0, 0, 400);
40
      delay(15);//delay for the servo to get to the position
41
42
43
    if (val == '2') //if value input is equals to 2
44
45
      myServo.setPWM(1, 0, 400);
46
47
48
    if (val == '3') //if value input is equals to 2
49
50
      myServo.setPWM(2, 0, 400);
51
52
53
    if (val == '4') //if value input is equals to 2
54
55
      myServo.setPWM(3, 0, 400);
56
57
58
    if (val == '5') //if value input is equals to 2
59
60
      myServo.setPWM(4, 0, 400);
61
62
63
    if (val == '6') //if value input is equals to 2
64
65
      myServo.setPWM(5, 0, 400);
66
67
68
    if (val == '7') //if value input is equals to 2
69
70
      myServo.setPWM(6, 0, 400);
71
72
73
74
    if (val == 'a') // zum wieder schließen!
75
76
77
78
79
80
81
    if (val == 's') //if value input is equals to 2
82
83
84
85
86
    if (val == 'd') //if value input is equals to 2
87
88
89
90
91
    if (val == 'f') //if value input is equals to 2
92
93
94
95
96
    if (val == 'g') //if value input is equals to 2
97
98
99
100
101
    if (val == 'h') //if value input is equals to 2
102
103
104
105
106
    if (val == 'j') //if value input is equals to 2
107
108
109
110
111
112
113
114
I´m sorry, if this isnt the right category for my question - I´m completely new to this forum!
A question of your own? This thread is over 2 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
