Forum: Compiler & IDEs Matlab GUI abhängig von Netwerkverbindung
von Michael D. (michael86)
Ich habe ein seltsames Problem mit Matlab.
Habe es unter OpenSUSE 15.5 installiert (Version R2023a) und das
Phänomen dass ich unter gewissen Umständen die grafische Oberfläche
nicht gestartet bekomme.
Unter normaler LAN-Verbindung:
michael@localhost:~> matlab
MATLAB is selecting SOFTWARE OPENGL rendering.
failed to open /usr/lib64/dri/hybrid_drv_video.so
Not using hybrid_drv_video.so
MESA-LOADER: failed to open crocus: /usr/local/MATLAB/R2023a/bin/glnxa64/../../sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.29' no
t found (required by /usr/lib64/dri/crocus_dri.so) (search paths /usr/lib64/dri, suffix _dri)
failed to load driver: crocus
MESA-LOADER: failed to open zink: /usr/local/MATLAB/R2023a/bin/glnxa64/../../sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.29' not
found (required by /usr/lib64/dri/zink_dri.so) (search paths /usr/lib64/dri, suffix _dri)
failed to load driver: zink
MESA-LOADER: failed to open kms_swrast: /usr/local/MATLAB/R2023a/bin/glnxa64/../../sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.29
' not found (required by /usr/lib64/dri/kms_swrast_dri.so) (search paths /usr/lib64/dri, suffix _dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast: /usr/local/MATLAB/R2023a/bin/glnxa64/../../sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.29' no
t found (required by /usr/lib64/dri/swrast_dri.so) (search paths /usr/lib64/dri, suffix _dri)
failed to load swrast driver
Gtk-Message: 21:29:20.224: Failed to load module "canberra-gtk-module"
GUI startet und keine Fehlermeldung in Matlab
Ohne Netzwerkverbindung:
Gtk-Message: 21:27:52.191: Failed to load module "canberra-gtk-module"
Und folgenden Fehler in Matlab
ERROR StatusLogger Could not determine local host name
 java.net.UnknownHostException: localhost.localdomain: localhost.localdomain: Name or service not known
  at java.net.InetAddress.getLocalHost(InetAddress.java:1506)
  at org.apache.logging.log4j.core.util.NetUtils.getLocalHostname(NetUtils.java:54)
  at org.apache.logging.log4j.core.LoggerContext.lambda$setConfiguration$0(LoggerContext.java:620)
  at java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1660)
  at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerContext.java:620)
  at org.apache.logging.log4j.core.LoggerContext.reconfigure(LoggerContext.java:699)
  at org.apache.logging.log4j.core.LoggerContext.reconfigure(LoggerContext.java:716)
  at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:270)
  at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:245)
  at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:47)
  at org.apache.logging.log4j.LogManager.getContext(LogManager.java:176)
  at org.apache.logging.log4j.LogManager.getLogger(LogManager.java:666)
  at com.mathworks.services.Log4JConfiguration.<clinit>(Log4JConfiguration.java:40)
  at java.lang.Class.forName0(Native Method)
  at java.lang.Class.forName(Class.java:264)
  at com.mathworks.util.PostVMInit$StartupClass.init(PostVMInit.java:172)
  at com.mathworks.util.PostVMInit.perform(PostVMInit.java:203)
Caused by: java.net.UnknownHostException: localhost.localdomain: Name or service not known
  at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
  at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:929)
  at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1324)
  at java.net.InetAddress.getLocalHost(InetAddress.java:1501)
  ... 16 more
Im WLAN
Authorization required, but no authorization protocol specified
                                                        < M A T L A B (R) >
                                              Copyright 1984-2023 The MathWorks, Inc.
                                         R2023a Update 6 (9.14.0.2489007) 64-bit (glnxa64)
                                                          January 3, 2024
To get started, type doc.
For product information, visit www.mathworks.com.
GUI startet nicht.
Kenn mich mit Matlab nicht wirklich aus und weiß auch erstmal gar nicht,
wo ich zum Suchen anfangen soll.
Jemand eine Idee? Danke.
von J. H. (neanderthaler)
Heißt dein Rechner wirklich localhost?
von Harald K. (kirnbichler)
Das ist der Fehler. Dein Rechner stellt keinen "host name" zur
Verfügung, wenn kein Netzwerk verfügbar ist.
von Jan K. (jan_k776)
Neuere Matlab Versionen machen mittlerweile alles über Netzwerk. Die GUI
ist nur noch ein Frontend.
Ich denke, du wirst ein konfiguriertes Netzwerk brauchen.
Ansonsten frage den Mathworks support.
danke, war wirklich der Rechnername. Habe ich jetzt fest vergeben und
funktioniert so weit auch.
Außer wenn kein Netzwerk verfügbar. Startet dann zwar aber habe eine
Fehlermeldung. Kann es sein, das Matlab beim Start immer die Lizenz
abgleicht?
Nebenbei noch. Mir ist aufgefallen, dass Matlab unter Linux um einiges
langsamer läuft als unter Windows. Ist das nur bei mir so?
von Norbert (der_norbert)
Geht's euch eigentlich auch so?
Kaum sehe ich ein Java Trace, leuchtet log4j rot blinkend auf!
> Fehlermeldung.
Die Fehlermeldung sieht so aus?
*  Fehlermeldung  *
... oder ist sie vielleicht doch etwas aussagekräftiger?
