I am hopeless (motor control system)
OP #7541972
Good morning to all dear friends, for those who have not followed my past problems, I have been asked to design a system that drives a DC motor with encoder (I will attach the text of the project). In all this time I managed to create a PWM, a PI regulator and recently I designed a system that counted the time elapsed between 2 pulses of channel A of the encoder to obtain the motor speed (which turned out to be a failure according to my professor because I wasn't taking into account the speed reducer installed on the DC motor). He advised me to use a reciprocal counter[(?) never heard of it] or if I have anything else in mind I'm free to do so. To tell the truth, I find myself once again in the dark tunnel of VHDL and I have no idea how to proceed and for this reason I ask for your opinion on how to calculate the speed of this quadrature encoder. A second problem I encountered is that of real numbers: taking the PI regulator as an example, when I calculate I, the product with the sampling period gives me a very small value that VHDL truncates to 0, how do I solve this problem? The professor told me that I have to use the 1.n representation, but he never explained how to implement it or anything close to it. I am truly desperate and unmotivated, I hope your words can lift me up, I thank you infinitely in advance. Marco
mia pi: is my pi.
mia pwm: is my pwm.
mio rilevatore: is my detector.
i'm sorry about the comments in italian language, if needed i'll proceed to translate them all.
project text link:https://www.celec.org/doku/doku.php?id=dafare (just for the images, if needed) Translated project text:Suppose you have available (they will be provided by the teacher) a DC motor equipped with a gearbox and a quadrature digital encoder and a full bridge driver to power the moder.
A digital system must be designed capable of maintaining constant the rotation speed of the motor which is supposed to be encoded on an 8-bit integer in two's complement notation.
The output of the digital system consists of the digital signals necessary for driving the bridge, i.e. a bit to indicate the direction of rotation and a PWM signal with the duty cycle proportional to the power to be sent to the motor.
The system must continuously monitor the quadrature encoder output to estimate the direction and magnitude of the rotational speed. Based on the estimated value and the reference input, the duty cycle of the output PWM signal must be modified in order to reach the set rotation speed.
Once the design of the digital system has been completed and its correct behavior has been verified through MODELSIM simulation, this must be integrated as part of a peripheral for NIOSII with the preparation of the control commands on serial line following the system on chip model developed in class.
The characteristics of the motor with encoder and the full bridge driver available are summarized in the figures.
For now just ignore the nios2 part
#7542098
What you are asking is essentially: "Please do all my homework for me"!
This is unlikely to happen.
If you count clock pulses between encoder pulses, then you get a numeric value that is ratiometric to the motor RPM. You can use this value in your PID loop.
If integer numbers go too small, then well you need to use fixed point arithmetic. With fixed point you still use integer operations, but you have "virtual" point somewhere in the logic vector. Say if you want to convert an integer to 16.16 fixed point then all you need todo is to shift the integer left 16 positions. Now you have fixed point value.
OP #7542124
I guess you didn't read the whole message, since it specifically says "I ask for your opinion on how to calculate the speed of this quadrature encoder". thanks anyway for your answer (I would add rather useless and offensive)
Guest #7544184
Why do I have the impression that FPGA designers become more and more unskilled? This is a piece of cake for an engineer.
Sorry, but why the hell do companies employ people who did not have learned about such easy things? A realization of a PWM-Controller is the most easy thing for beginners, unless they are only programmers and have no idea about hardware.
However, a PWM might be even the false solution for you problem in detail because of the required reaction time of the control logic.
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
