Help understanding Neon intrinsics
OP #7465547
Hi everyone,
I am new to Arm Neon programming, and am having a very difficult time making sense of the conventions for mapping gcc intrinsics to actual Arm Neon v8 instructions. Can someone explain to me how to do the following:
I am making a custom hashing function that uses AES rounds. All the data is byte wide and in fixed blocks of 16MB, and I am just trying to pipe it into the ARM Neon core as quickly as possible. From reading the Arm developer documentation here:
https://developer.arm.com/documentation/ddi0596/2021-03/SIMD-FP-Instructions/LD1--multiple-structures---Load-multiple-single-element-structures-to-one--two--three--or-four-registers-?lang=en
I want to use a sequence of these instructions:
LD1  {  V0.16B,  V1.16B,  V2.16B,  V3.16B }, [x0], #64
LD1  {  V4.16B,  V5.16B,  V6.16B,  V7.16B }, [x0], #64
However, after reading this page:
https://arm-software.github.io/acle/neon_intrinsics/advsimd.html#load-1
I can't find any intrinsic which actually generates this instruction, let alone the GCC convention for using these intrinsics.
Can someone give me an example of a simple C program, compilable by gcc (preferably v9.4 as that is what is available on Ubuntu Bionic, the version running on the embedded platform), that can access these instructions? I'm fine with embedded assembly if that is what is necessary, but I can't figure out the correct syntax to make it work.
Thank you for any advice.
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
