Looking for recommendation for full-bridge IC
OP #7339710
Good morning folks,
my problem in short: I'm looking for the right full-bridge IC (single or double). I would like to be able to both power it and control it with 24V and the output voltage should also be +-24V. The load is only around 40mA. Does anyone have a good suggestion?
Detailed explanation: At work I'm working on a self-made model of an electric motor. Right now it's built with a rotor with permanent magnets, which is turned by 6 individual coils, which I removed from old relais. The coils are controlled with 24V by a PLC.
To improve the system I would like to be able to change the polarity of the coils while running the motor. With the normal digital outputs of the PLC I'm limited to only one polarity and analogue outputs provide only +-10V. After a day of research and puzzling about MOSFETs and full-bridges I let go of the idea of building my own bridges, because I'm lacking the know-how at this point. That's why I'm looking for fitting full-bridge ICs to individually control the coils. The requirements would be that I can both power and control the chip with 24V via the PLC and that the output voltage is also 24V, which is the nominal value for the coils.
Greetings
Wolfgang
OP #7339812
Thank you for the suggestions! I looked into the L272 and it raised some questions for me:
In the datasheet, there's an example for how to drive a DC motor. What is the meaning of that new Value Vs1? Is that just supposed to set the voltage difference between the output pins? If so, should that be ground if I want to run the coils with 24V? And if so, could those inputs be shorted to ground if I dont wish to modulate the voltage? [page 5, Figure 9]
Another issue is power dissipation. With a supply voltage of 24V I get 200mW of power from just the circuitry and having a 40mA load adds another 600mW. 800mW is within bounds, but should I perhaps take extra care to glue a piece of metal on top to better dissipate heat?
Last is concerning switching the direction. Could too sudden of a switch result in a potential of 48V for a moment because of the impedance of the coil?
Edit: Sorry, missed your bipolar supply requirements. I don't quite understand what you mean?
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
