Puls generator
OP #7323656
Hi, I have a multi stage process and each step need some time. I want to create some sequencer which is able to generate positive edges at certain intervals and at the end /beginning of the cycle reset this signals. Not that complicated, I thought, but I fail totally.
If I do it in hardware: Counter, 11 bit wide, increments at each clock cycle, some comparators, comparing the actual count against a constant and if equal, set the output for one clock cycle, ==> get my positive edge.
If I do it in Verilog:
always @ (negedge clk)
    begin
      if ( reset )
        reg_step = 3'd0;
        else
        if ( reg_step < 8'd240 || reg_sel != 3'd7 ) reg_step <= ( reg_step == 8'd240 ) ? 8'd0 : reg_step + 8'd1;
    end
  // Generate stage clocks and incremet wave index
  always @ (posedge clk)
    if ( reset )
      begin
        reg_sel      = 3'd7;
        reg_accu_clk  =    0;
        reg_lut_clk    =    0;
        reg_mix_clk    =    0;
      end
    else
      case ( reg_step )
        8'd2:
          begin
            reg_sel      = reg_sel + 3'd1;
            reg_accu_clk  = 0;
            reg_lut_clk    = 0;
            reg_mix_clk    = 0;
          end
        8'd10:
30
          reg_accu_clk <= 1;
31
        8'd20:
32
          reg_lut_clk   <= 1;
33
        8'd200:                          // 100 .. fails, 150 works, 150-20 = 130 * 2.5ns = 325 ns for the 12 bit sin_lut
34
          reg_mix_clk  <= 1;
35
      endcase
36
37
38
    begin
39
      if ( reg_step == 8'd2 )
40
        begin
41
42
          reg_accu_clk  = 0;
43
          reg_lut_clk    = 0;
44
          reg_mix_clk    = 0;
45
        end
46
47
      if ( reg_step == 8'd10 )  reg_accu_clk  <= 1;
48
49
      if ( reg_step == 8'd20 )  reg_lut_clk  <= 1;
50
51
      if ( reg_step == 8'd200 ) reg_mix_clk  <= 1;
52
    end
I tried two options. In the simulation, everything is fine. In real nothing works.
I use the RTL viewer and it was funny to see what the compiler thought that I want to do.
Can some body help me and tell me, how I can implement such a simple sequencer in Verilog or should I better start drawing a schematic using primitives in my Quartus Prime?
What is the target: At negedge, the counter advances/resets. At the posedge (the counter value is stable I guess ...) the counter value is compared with some constants and if there is one found to be equal, the output is 1, 0 otherwise.
I get posedges at certain poits in time (relative to the start), synchronized with the posedge of my clock.
Sorry about code formatting ..
With best regards
Gerhard
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
