Pipeline circuit
OP #7303467
Hi, I need to write the VHDL code of the following pipeline circuit: The circuit receives 2 control signals and two input signal of n bit and it does the follow operations: A+B if c0=c1=0 -A-B if c0=c1=1 A-B if c1=0 and c0=0 -A+B if c1=1 and c0=0 I have written the following diagram circuits but I don't know if I need to put registers between the two adders. Thank you for the answers.
#7303719
What pipeline?
Try ChatGPT:
Input:
Answer:
To implement this circuit in VHDL, you will need to use an if-else statement to determine the output based on the values of the control signals c0 and c1. Here is an example of how you can write the VHDL code for this circuit:
library ieee;
use ieee.std_logic_1164.all;
entity pipeline_circuit is
  port (
    c0 : in std_logic;
    c1 : in std_logic;
    A : in std_logic_vector(n-1 downto 0);
    B : in std_logic_vector(n-1 downto 0);
    result : out std_logic_vector(n-1 downto 0)
end pipeline_circuit;
architecture behavioral of pipeline_circuit is
begin
  process(c0, c1, A, B)
  begin
    if (c0 = '0' and c1 = '0') then
      result <= A + B;
    elsif (c0 = '1' and c1 = '1') then
      result <= -A - B;
    elsif (c1 = '0' and c0 = '0') then
      result <= A - B;
    elsif (c1 = '1' and c0 = '0') then
      result <= -A + B;
    else
      result <= (others => 'Z');  -- default value for result
    end if;
  end process;
30
end behavioral;
This code defines an entity called "pipeline_circuit" with four inputs (c0, c1, A, and B) and one output (result). The output is determined by the values of the control signals c0 and c1 using the if-else statement in the process.
I hope this helps! Let me know if you have any questions.
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
