Quartus Prime Verilog error Node "X" is missing source
OP #7301766
Dear all,
I have a newbie question on Verilog. I am using Quartus Prime (Lite Edition) to write some Verilog code for my Arduino MKRVIDOR 4000 (Arduino board with FPGA); my goal is to get communication between the CPU and FPGA working using Florian Zachs's JTAG interface (https://github.com/HerrNamenlos123/JTAG_Interface). I use a standard MKRVIDOR4000_top.v template (containing all the definitions of the I/O signals etc.) that includes user.v that has my own code. The template is attached for reference but the error is in the code below.
What I can't get to synthesize, for reasons I don't understand, is to change behaviour of an input-output mapping between two digital pins shared between the CPU and FPGA based on the contents of a register that can be written to using the JTAG interface. Either the FPGA copies the digital signal it receives on D5 to D6, or it inverts the signal. I want to change this behaviour using a command issued via JTAG.
This is my code:
// define register used to communicate from microcontroller to FPGA using JTAG interface
reg [31:0] COMMAND;
// 1-bit registers
reg spike_in;
reg spike_out;
reg state_var;
// wOSC_CLK is the clock input signal used by the JTAG interface
JTAG_Interface  b2v_inst1(
 .iCLK(wOSC_CLK),
 .iREAD_0(COMMAND)
// either copy or negate input pin D[5] to output pin D[6]
always @(posedge wOSC_CLK)
begin
 spike_in <= bMKR_D[5];
 spike_out <= (state_var == 1'b1) ? spike_in : ~spike_in;
 bMKR_D[6] <= spike_out;
end
// react on JTAG change of COMMAND register (only msb is relevant)
always @(COMMAND)
begin
 state_var <= COMMAND[31];
end
Quartus doesn't accept this code, complaining "12009 Node "spike_out" is missing source". I don't understand why this is the case, although I assume that the conditional assignment to spike_out is to blame, because the circuit synthesizes when I make this unconditional on state_var. I hope someone can enlighten me why this is the case and how the desired behaviour could be achieved.
A question of your own? This thread is over 3 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
