PTH on the Edge
OP (Company: ​King Credie Technology Ltd) #7116619
It is also called “castellated holes”. These are plated holes cut
through on the board edge and used to join two PCBs either by direct
soldering or via a connector.  During the production, it is necessary to
pre-process the semi-hole position before etching circuit to make sure
the semi-hole position is smooth and no burr.
Process capability:
The hole diameter on the edge is minimum 0.6MM, and the half hole should
be drilled inside the boards ≥0.3MM
Notice:
The spacing between castellated holes should be greater than 0.55MM, or
it will easily cause short circuit.
For other PCB technology, such as Countersink, Depth Routing, please
visit the below website:
https://www.kingcredie.com/Ab_index_gci_35.html
Start a new thread
