Making a counter using VHDL
OP #7000555
I want to make a counter that on every rising clock edge, adds 1 to my
'counter' out and resets on a rising edge if 'reset = 1'. I had problems
with working directly on the 'counter', so I have the extra signal
'countr' as a temp.
However, when I run that code, it only adds 1 every two rising edges.
Can someone explain why?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Counter is
port (
    clk : in std_logic;
    reset : in std_logic;
    count : out std_logic_vector(3 downto 0)
end Counter;
architecture rtl of Counter is
signal countr : std_logic_vector(3 downto 0);
begin
    process(clk)
    begin
        if(rising_edge(clk)) then
            countr <= std_logic_vector(to_unsigned(to_integer(unsigned(countr)) + 1, 4));
            if(reset = '1') then
                countr <= (others => '0');
            end if;
        end if;
        count <= countr;
    end process;
end architecture rtl;
Guest #7000559
The assignment count <= countr is inside the process, which is only
activated by simulator when the clk signal changes (see sensitivity
list).
Just write it outside the process:
library ieee;
entity Counter is
port (
    clk : in std_logic;
end entity Counter;
    signal countr : unsigned(3 downto 0);
begin
    process(clk)
    begin
            countr <= countr + 1;
            if reset = '1' then
            end if;
        end if;
    end process;
    count <= std_logic_vector( countr);
30
31
Duke
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
