Forum: PC-Programmierung [JS/PHP] Wie globale Session Variable setzen und lesen
von Rene K. (xdraconix)
Ich habe hier ein kleines Problem.
Ich habe eine Hauptseite, welche eine Unterseite lädt. Diese hat die
Document.ready() Funktion.
Overview.php
<div class="OverviewMain">
  <div class="OverviewLeft" id="R1">Right</div>
  <div class="OverviewBig1" id="B1">Big1</div>
  <div class="OverviewBig2" id="B2">Big2</div>
  <div class="OverviewSmall1" id="S1">Lade</div>
  <div class="OverviewSmall2" id="S2">Lade</div>
  <div class="OverviewLeft1"><img src="data/images/thermo1.svg" height="75" width="75"/><span id="T1">0.00°C</span></div>
  <div class="OverviewLeft2"><img src="data/images/thermo1.svg" height="75" width="75"/><span id="T2">0.00°C</span></div>
  <div class="OverviewLeft3"><img src="data/images/thermo1.svg" height="75" width="75"/><span id="T3">0.00°C</span></div>
</div>
<script language="javascript" type="text/javascript">
$(document).ready(function(){
    refreshSmall1();
    refreshJSON();
function refreshSmall1(){
    $('#S2').load('ajax_temp_chart.php?id=2');
    $('#T1').load('ajax_temp_val.php?id=1');
    $('#T2').load('ajax_temp_val.php?id=2');
    $('#S1').load('ajax_temp_chart.php?id=1', function(){setTimeout(refreshSmall1, 500);});
function refreshJSON(){
   $('#R1').load('ajax_JSON.php', function(){setTimeout(refreshJSON, 1000);});
</script>
Die dazugehörigen Dateien, welche mir kopfzerbrechen machen sind
ajax_temp_val.php und ajax_JSON.php.
ajax_temp_val.php
<?php
   if(isset($_SESSION['temp1'])) {
        echo $_SESSION['temp1']."°C";
   } else {
        echo "nOK";
ajax_JSON.php
<?php
    $socket = socket_create(AF_INET, SOCK_DGRAM, SOL_UDP);
    socket_set_option($socket, SOL_SOCKET, SO_BROADCAST, 1);
    socket_set_option($socket, SOL_SOCKET, SO_RCVTIMEO, array("sec"=>10, "usec"=>0));
    socket_bind($socket, '192.168.166.1', 20005);
    socket_recvfrom($socket, $buf, 1000, 0, $from, $port);
    $JSonVar = json_decode($buf);
    $_SESSION['temp1'] = $JSonVar->temp1;
    //echo "OK";
    socket_close($socket);
Das laden des JSON UDP Streams funktioniert tadellos und auch das setzen
der Variable $_SESSION funktioniert, da mir über echo
$_SESSION['temp1']."°C"; die richtigen Werte ausgegeben werden.
Jedoch müsste, da es sich um eine Seitenweite Session handelt, (
session_start() steht in der Index.php über welche sämtliche Seiten
geladen werden) ja dann die Variable auch bei einem späteren Aufruf von
ajax_temp_val.php verfügbar sein. Ist sie aber leider nicht.
ajax_temp_chart.php greift noch Datenbank gebunden auf die Daten zu,
dies ist aktuell nicht von belangen.
Hat da jemand einen Tipp für mich?!
von Εrnst B. (ernst)
> geladen werden)
Bist du dir da sicher?
> $('#R1').load('ajax_JSON.php'...
macht direkt einen Request auf die ajax_JSON.php, nicht auf die
index.php.
Wenn du da nicht einen Satz .htaccess Rules o.Ä. zum Umschreiben des
Requests hast, läuft dieser Request (und auch die anderen
ajax_temp_*.php) nicht über die index.php.
Ahh ich sehe, also wenn ich vor jedes Script welches auf die SESSION
zugreifen will / muss ein session_start() schreibe dann funktioniert
dies auch.
Mich verwundert dies schon ein wenig, denn mein logisches Verständnis
sagt mir ja:
index.php session.start() -> overview.php
                                 |-> ajax_JSON.php
                                 |-> aja_temp_val.php
demnach wäre in meinem Verständnis die Session immernoch aktiv und
könnte geschrieben und gelesen werden. Aber okay, wieder was gelernt.
Vielen Dank dir.
Vereinfacht:
es gibt bei der php-session drei verschiedene Voraussetzungen für
"aktiv":
1) Das PHP-SESSION-ID Cookie lebt noch im Browser
2) Die mit diesem Cookie verknüpften Daten existieren noch am Webserver
3) die gerade ausgeführte PHP-Seite hat das Cookie (1) benutzt, um die
Daten (2) in die $_SESSION - Variable zu laden
session_start() kümmert sich um alle drei, und, vor allem, stößt (3) an.
von Purzel H. (hacky)
Globale php Variablen :
session_start();
$_SESSION['myvar']=123;
$_SESSION['anothervar']='abc';
> session_start();
Das Problem lag ja nicht im setzen sondern im lesen:
$var = $_SESSION['myvar'];
in Verbindung der Abhängikeit von session_start() welche nicht nicht nur
im Parent Dokument sondern auch im per jquery nachgeladenen Child
beinhaltet sein muss.
Funktioniert jetzt übrigens tadellos (siehe Bild), und schön auch das
man eine Session Variable auch ein Objekt oder ein Multi-Array
mitschicken kann.
