VexRiscV system with GDB-Server in Hardware
Guest #6955137
For all who are interested I have set up a small VexRiscV System with
Wishbone Bus running on a BASYS3-Board from Digilent.
The specific feature of this system is the embedded GDB-Server in
Hardware which receives the RSP-commands from the GDB and creates
suitable commands for the VexRiscV debug bus. Thus the GDB can directly
connect to the system via serial port without a software GDB-Server
(like e.g. OpenOCD or others).
The Project is available via Github:
https://github.com/BLangOS/VexRiscV_with_HW-GDB_Server.
It is no problem to port the System to other platforms.
Have fun.
Guest #6955900
Interesting approach to put this into pure hardware, but I strongly
believe you'll get more 'love' with implementing a proper JTAG protocol
directly to the core (avoiding the puzzling RISC-V debug interface
design).
I tend to stay away from the serial gdb server protocol as far as I can
due to stability issues seen in the past. When it comes to debugging:
Keep it as simple as possible, use in-circuit-emulation only.
Guest #6956217
From my viewpoint the "the puzzling RISC-V debug interface" is a very
interesting interface directly into the core of the VexRiscV, which
allows to adapt different frontends for debugging.
If you don't want to spend much hardware for the debug interface, you
are definitely better off with JTAG. There is already a JTAG interface
available for the VexRiscV processor and a related OpenOCD port.
The approach presented here serves to make access to the processor from
the development environment view "as simple as possible". Beginners in
particular often find it very difficult to put the necessary environment
of debugger, GDB server and suitable debug interface together to debug
self-designed processor systems in FPGAs.
The presented GDB server in hardware simplifies experimenting with the
very interesting VexRiscV. With the Basys3 board, you only need a single
USB connection to the PC. The board is first configured via this
connection and then the GDB debugger can be directely connected to the
GDB server via the COM port of the same USB connection.
I am surprised that you address stability issues of other systems you
have seen in the past at this point. This GDB-Server runs very stable.
This has to be the case, since it is also used in training courses for
beginners in FPGA design and computer organization.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
