Quadruple Half-H Drivers
Guest #6856320
The L293 and L293D are high-current quadruple half-H drivers. These
devices are intended to power a variety of inductive loads, including
relays, solenoids, DC and bipolar stepping motors, and other
high-current and high-voltage loads. All inputs are TTL compatible and
can withstand voltages of up to 7 V. Each output is an entire totem-pole
drive circuit, complete with a Darlington transistor sink and a
pseudo-Darlington source. Drivers are enabled in pairs, with 1,2EN
enabling drivers 1 and 2 and 3,4EN enabling drivers 3 and 4.
I have learned L293DNE from this article:
https://www.apogeeweb.net/circuitry/l293dne-quadruple-half-h-drivers-datasheet-arduino-pinout.html
If you get more ideas, please tell me.
Guest #6857237
IC from the last century.
Using bipolar darlington as drivers, the IC typically loses 1,4V at the
highside and 1.2V at the lowside.
If you e.g. want to drive a 12V-Motor, a 12V-Power-supply will result in
only 9.4V at the motor.
Modern ICs have lower losses and allow for higher currents at comparable
prices. Additionally, many of them have open-loop detection or
overcurrent-protection.
Start a new thread
