Strain gauge based on Arduino
OP #6830018
The strain assessment instrument is used to assess the degree of
corresponding muscle strain by obtaining the muscle surface action
potential through silver oxide electrodes or other human surface
electrodes, together with the patient's conscious control of muscle
movements. The highest level of muscle strain is 7 and the lowest level
is 1. Level 1 is a mild condition, followed by levels 2, 3, 4, and 5,
and levels 6 and 7 are severe conditions. This project uses the serial
touch screen animation to display the evaluation process, and the end of
the evaluation will give the level of the proposed treatment plan
display. The accessories are as follows.
1, STONE 5.6" serial touch screen and adapter board V1.2.
2, electrodes, electrode wires.
3, Arduino EMG feedback module.
The result demonstration is shown in the attached image.
OP #6830019
//EMG assess is testing for people.
// by Frank 20210326.
#include <Servo.h>
int pos = 0;    // variable to store the servo position
int inDelay = 0;
String inString = "";    // String buffer
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;       // in pcba
int led2 = 12;       // yellow
int led3 = 11;       // red
int ipage = 1;         //  Pointer buffer 1-7
int ipage0;            //  Pointer buffer 1-7
int ipage2;            //  Pointer buffer 1-7
int biaozhi = 0;  // 1 = begin, 0 = stop.
int threeok;      // 3 = trun to reslut page  and biaozhi zero,
int dataMuscle = 0;   // The muscle data of testing.
void setup()
   pinMode(led, OUTPUT);        // initialize the digital pin as an output.
  pinMode(led2, OUTPUT);        // initialize the digital pin as an output.
  pinMode(led3, OUTPUT);        // initialize the digital pin as an output.
  Serial.begin(9600);  // Open the serial communication function and wait for the serial port to open
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
void loop()
30
31
  int inChar;
32
  if(inDelay == 0){
33
       inDelay = 1;                //RTC is only once!
34
      //-------------------------RTC--------------------------
35
        Serial.write(0xA5);       //"A5" is 165
36
        Serial.write(0x5A);       //"5A" is 90
37
        Serial.write(0x0A);
38
        Serial.write(0x80);
39
        Serial.write(0x1F);
40
        Serial.write(0x5A);
41
        Serial.write(0x21);
42
        Serial.write(0x03);
43
        Serial.write(0x26);            // 3 month 26 day
44
        Serial.write(0x05);            // friday
45
        Serial.write(0x11);
46
        Serial.write(0x08);
47
        Serial.write(0x57);           // 11:08:57
48
49
50
  // Read the information sent by the serial port:
51
  if (Serial.available() > 0)   {    inChar = Serial.read();  }
52
  /* begin key is biaozhi = 1 ! */
53
  if ((inChar == 0x61)&&(biaozhi == 0)) {        // 0x0061 is the begin key !
54
     biaozhi = 1;
55
     threeok = 0;
56
     dataMuscle = random(1,7);            //shui ji shu (1-7)   ,it is the result num!
57
     ipage2 = 0;
58
     ipage3 = 0;
59
60
  /*-------------------------------------EMG assess begin------------------------------*/
61
  if(biaozhi == 1)     // begin EMG assess testing!
62
63
     digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
64
    //------------------------------------------1------------------------------------------
65
     if (ipage < 7)            // only begin look each page!
66
67
         for(ipage0 = ipage; ipage0 < 7; ipage0 += 1)      // Num 1+
68
69
              // variable Icon + 1
70
71
72
            Serial.write(0x05);
73
            Serial.write(0x82);
74
            Serial.write(0x03);
75
            Serial.write(0x00);
76
            Serial.write(0x00);
77
            Serial.write(ipage0);    // 0-7 page all can look!
78
            delay(600);              // waits 0.6s
79
            if((ipage0 == (dataMuscle + 1))&&(ipage2 == 0)){
80
              ipage2 = 1;
81
              ipage0 -= 2;
82
83
84
        ipage = 7;
85
        ipage2 = 0;
86
        digitalWrite(led3, HIGH);   // turn the LED on (HIGH is the voltage level)
87
        for(ipage0 = ipage; ipage0 > 0; ipage0 -= 1)  // Num 1-
88
89
90
91
          Serial.write(0x05);
92
          Serial.write(0x82);
93
          Serial.write(0x03);
94
          Serial.write(0x00);
95
          Serial.write(0x00);
96
          Serial.write(ipage0);    // 01-7 page all can look!
97
          delay(900);              // waits 0.9s
98
          if((ipage0 == (dataMuscle - 1))&&(ipage2 == 0)){
99
              ipage2 = 1;
100
              ipage0 += 2;
101
102
103
        ipage = 1;
104
        ipage2 = 0;
105
106
    threeok = 1;
107
    //----------------------------------------2------------------------------------------
108
       digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
109
     digitalWrite(led2, HIGH);    // turn the LED off by making the voltage LOW
110
     digitalWrite(led3, LOW);    // turn the LED off by making the voltage LOW
111
112
113
114
115
116
117
118
        Serial.write(0x05);
119
        Serial.write(0x82);
120
        Serial.write(0x03);
121
        Serial.write(0x00);
122
        Serial.write(0x00);
123
        Serial.write(ipage0);    // 1-7 page all can look!
124
        delay(500);              // waits 0.6s
125
126
           ipage2 = 1;
127
           ipage0 -= 2;
128
129
130
      ipage = 7;
131
      ipage2 = 0;
132
133
134
135
136
137
        Serial.write(0x05);
138
        Serial.write(0x82);
139
        Serial.write(0x03);
140
        Serial.write(0x00);
141
        Serial.write(0x00);
142
143
        delay(800);              // waits 0.9s
144
145
            ipage2 = 1;
146
            ipage0 += 2;
147
148
149
      ipage = 1;
150
      ipage2 = 0;
151
152
    threeok = 2;
153
    //------------------------------------------3------------------------------------------
154
155
     digitalWrite(led2, LOW);    // turn the LED off by making the voltage LOW
156
     digitalWrite(led3, HIGH);    // turn the LED off by making the voltage LOW
157
158
159
160
161
162
163
164
        Serial.write(0x05);
165
        Serial.write(0x82);
166
        Serial.write(0x03);
167
        Serial.write(0x00);
168
        Serial.write(0x00);
169
170
        delay(300);              // waits 0.6s
171
172
            ipage2 = 1;
173
            ipage0 -= 2;
174
175
176
      ipage = 7;
177
      ipage2 = 0;
178
179
180
181
182
183
        Serial.write(0x05);
184
        Serial.write(0x82);
185
        Serial.write(0x03);
186
        Serial.write(0x00);
187
        Serial.write(0x00);
188
189
        delay(600);              // waits 0.9s
190
191
            ipage2 = 1;
192
            ipage0 += 2;
193
194
195
      ipage = 1;
196
      ipage2 = 0;
197
198
   threeok = 3;
199
  }// end if(biaozhi == 1)
200
  /*-------------------------------------EMG assess  END -----------------------------*/
201
202
  if(threeok == 3)      // 3 = trun to reslut page  and biaozhi zero,
203
204
    biaozhi = 0;
205
    threeok = 0;
206
    //trun reslut page.
207
208
209
        Serial.write(0x04);
210
        Serial.write(0x80);
211
        Serial.write(0x03);
212
        Serial.write(0x00);
213
        Serial.write(dataMuscle);
214
215
216
217
  }//end if(threeok == 3)
218
Start a new thread
