STM32H7 bank swap break at address 0x81006fe
Guest #6798027
I trying to do a bank swap with the ST32 H743ZI2. I wasted much of time
to fix it but i didnt get it. Maybe because im new in STM32 controllers.
I copied the bank swap code from STM32CubeH7 Firmware Examples and did a
few modifications regarding to gpio configuration in CubeMX. I did them
because i want to implicate the code in a excisting project without the
stm32h7xx_nucleo headers.
Following the Code for Bank1:
HAL_FLASH_Unlock();
HAL_FLASH_OB_Unlock();
while (1)
    /* Wait for BUTTON_USER is released */
    if (HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_13) == 1)
  while (HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_13) == 1);
  /* Get the Dual boot configuration status */
  HAL_FLASHEx_OBGetConfig(&OBInit);
  /* Get FLASH_WRP_SECTORS write protection status */
  OBInit.Banks     = FLASH_BANK_1;
  /* Check Swap FLASH banks  status */
  if ((OBInit.USERConfig & OB_SWAP_BANK_ENABLE) == OB_SWAP_BANK_DISABLE)
    /*Swap to bank2 */
    /*Set OB SWAP_BANK_OPT to swap Bank2*/
    OBInit.OptionType = OPTIONBYTE_USER;
    OBInit.USERType   = OB_USER_SWAP_BANK;
    OBInit.USERConfig = OB_SWAP_BANK_ENABLE;
    HAL_FLASHEx_OBProgram(&OBInit);
    /* Launch Option bytes loading */
    HAL_FLASH_OB_Launch();
30
31
32
      as the  CPU is executing from the FLASH Bank1, and the I-Cache is enabled :
33
      Instruction cache must be invalidated after bank switching to ensure that
34
      CPU will fetch correct instructions from the FLASH.
35
36
    SCB_InvalidateICache();
37
38
39
    HAL_NVIC_SystemReset();
40
41
  else
42
43
    /* Swap to bank1 */
44
    /*Set OB SWAP_BANK_OPT to swap Bank1*/
45
46
47
    OBInit.USERConfig = OB_SWAP_BANK_DISABLE;
48
49
50
51
52
53
54
55
56
57
58
59
60
61
else
62
63
#ifdef FLASH_BANK1
64
    /* Toggle LED1 */
65
66
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_0);
67
/*Turn Off LED2*/
68
HAL_GPIO_WritePin(GPIOE, GPIO_PIN_1, 0);
69
70
#else
71
      /* Toggle LED2 */
72
    HAL_GPIO_TogglePin(GPIOE, GPIO_PIN_1);
73
      /* Turn off LED1 */
74
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, 0);
75
#endif
76
77
  /* Insert 100 ms delay */
78
  HAL_Delay(100);
79
80
81
/* USER CODE END WHILE */
82
83
  /* USER CODE BEGIN 3 */
84
85
  /* USER CODE END 3 */
86
The code for bank1 and bank2 are equal except linkerscript. I splited
Flash in two areas wich have 1024kb each. In following you can see the
code for bank1.
/* Specify the memory areas */
MEMORY
  RAM (xrw)      : ORIGIN = 0x20000000, LENGTH = 128K
  RAM_D1 (xrw)   : ORIGIN = 0x24000000, LENGTH = 512K
  RAM_D2 (xrw)   : ORIGIN = 0x30000000, LENGTH = 288K
  RAM_D3 (xrw)   : ORIGIN = 0x38000000, LENGTH = 64K
  ITCMRAM (xrw)  : ORIGIN = 0x00000000, LENGTH = 64K
  FLASH (rx)     : ORIGIN = 0x8000000, LENGTH = 1024K
In linkerscript for bank2 i changed flash start addres to 0x08100000.
Now i have following problem. If i load in order code for bank1 and code
for bank2 press the Button1 and Press the Resetbutton i get following
error message:
Break at address "0x81006fe" with no debug information available, or outside of program code.
I already successfully checked if there is placed some code with STM32
Utility.
If i load the codes in reverse order the banks get swaped once.
Independently if Button1 gets pressed before system reset or not..
I already checked some forums without success.
Does anyone know where the problem could be?
Guest #6798033
The main problem is that you aren't willing to follow the
rules for posting program code.
So I'm not willing to really look at your problem ....
#6798099
You mean because it´s a long code? Sorry didnt know that 90 lines are to
long..
Rules violation wasnt my intention. I tried to edit the post
unfortunately there are problems with my email host so i didnt get some
mail from embdev.net or microcontoller.net. I would do a new post but i
thinks its against the rules too.
As soon as i can edit the post i will do it.
Maybe you can forgive this serious mistake. In case you did the code in
question and the complete code is in attachment.
Start a new thread
