STM32F407 software trigger a one pulse timer using HAL
#6778168
I don't know if there is a special HAL way to do this.
But why not setting the corresponding bit in one of the "interrupt set
pending register" NVIC_ISPR0 through NVIC_ISPR7?
See:
 Cortex M4 M4 Devices Generic User Guide
https://developer.arm.com/documentation/dui0553/a/
"4.2.4 Interrupt Set-pending Registers"
There should also be a CMSIS function NVIC_SetPendingIRQ(IRQn_Type
IRQn), see "4.2.1 Accessing the Cortex M4 NVIC registers using CMSIS"
After setting the bit I expect the IRQ to run (if enabled and no higher
prio interrupt running).
Guest #7208311
Hi, I think you can use __HAL_TIM_ENABLE(&htim1) to enable short pulse
after setup that timer (e.g. TIM1) to work in OPM mode.
Start a new thread
