Ardu Tester with Uno board
OP (Company: n/a) #6752596
Hi all,
I just joined this forum and I have a question please.
I have set up the Ard-tester on a breadboard using an Arduino Uno, an
20x4 LC display with I2c interface. The I2C interface is connected the
the SDA and SCL pin on the Arduino.
The six resistors are connected to pin # D8,9,10,11,12 and 13 and the
combination d8/9 to pin A0, D10/11 to A1 and D12/13 to A2, hence becomng
TP1, TP2 and TP3 accordingly.
So far I have and can measure resistors, capacitors and transistors with
between 1.5 and 5% accuracy. Note: the 6 resistors are 10% plus/minus,
but will be replaced by the more accurate 0.1% resistors once all
problems are sorted out.
My question:
Can I substitute D6 and D7 for D12 and D13 to avoid influence from the
internal LED and pull-up resistor on the Uno board????
If so, how can I do this? Your advice please
Thanks.
Kind regards/Best 73's de Eb W. ZL4RM/PA0JAG
Start a new thread
