Applications where a transimpedance amplifier is used for measuring small sine AC currents.
Guest #6699777
Dear all,
for a thesis I'm looking for applications where a transimpedance
amplifier is used for measuring a small sine wave current (AC current).
Means on the non inverting input of the transimpedance amplifier (TIA) a
reference sine signal is conneted. On the inverting input a sensor is
connected. As soon as the sensor draws a current this current leads to a
change in voltage of the TIA output.
I would be very glad when you could send me examples where a wiring like
this is realized.
Kind Regards
Ron
Guest #6965927
You noticed that applying a voltage to the noninverting input will
either change the voltage across the sensor accordingly or (if that’s
not possible) force the output of the TIA into one of its rails? I
couldn’t imagine why you would use such a measurement setup on a DUT.
Start a new thread
