Forum: Test test format code
von Mitleserin (a.b.) (Gast)
[code struct CLASS_NAME {
    using DataT = DATA_TYPE;
    static volatile DataT*  Addr()     {return &REG_NAME
    static DataT Get       ()          {return  REG_NAME
    static void  Set       (auto value){        REG_NAME  =
DataT(value);} \
    static void  Or        (auto value){        REG_NAME |=
DataT(value);} \
    static void  And       (auto value){        REG_NAME &=
DataT(value);} \
    static void  Xor       (auto value){        REG_NAME ^=
DataT(value);} \
    static void  AndOr     (auto andMask,
                            auto orMask ) {     REG_NAME  =
                                              ( REG_NAME  & DataT(
andMask)\
DataT(orMask);}\
    static void  ClrSet    (auto andMask,
                                              ( REG_NAME  &
DataT(~andMask)\
DataT(orMask);}\
    static bool  BitIsSet  (auto mask) {return (REG_NAME &
DataT(mask));}  \
    static bool  BitIsClear(auto mask) {return!(REG_NAME &
DataT(mask));}  \
  };[/code]
Beitrag #6759012 wurde von einem Moderator gelöscht.
von Al. K. (alterknacker)
ja,so ist es
von A. B. (Firma: ab) (bus_eng)
template<>
struct TimerRegs<3> { ...                             // ATmega1284
   enum class tmode : DataT  {
      wgm0                         = 1 << WGM10,      // waveform0 gen. mode TCCRA | bit0
      wgm1                         = 1 << WGM11,      // waveform0 gen. mode TCCRA | bit1
      wgm2                         = 1 << WGM12,      // waveform0 gen. mode TCCRB | bit3
      wgm3                         = 1 << WGM13,      // waveform0 gen. mode TCCRB | bit4
      Normal                       = 0,
      PwmPhaseCorrect8Bit          =                wgm0,
      PwmPhaseCorrect9Bit          =           wgm1,
      PwmPhaseCorrect10Bit         =           wgm1|wgm0,
      ClearOnCompareOCRA           =      wgm2,
      PwmFast8Bit                  =      wgm2|     wgm0,
      PwmFast9Bit                  =      wgm2|wgm1,
      PwmFast10Bit                 =      wgm2|wgm1|wgm0,
      PwmPhaseAndFreqCorrectToICR  = wgm3,
      PwmPhaseAndFreqCorrectToOCRA = wgm3|          wgm0,
      PwmPhaseCorrectToICR         = wgm3|     wgm1,
      PwmPhaseCorrectToOCRA        = wgm3|     wgm1|wgm0,
      ClearOnCompareICR            = wgm3|wgm2,
   // Reserved                     = wgm3|wgm2|     wgm0,
      PwmFastToICR                 = wgm3|wgm2|wgm1,
      PwmFastToOCRA                = wgm3|wgm2|wgm1|wgm0,
30
      clearmask_cca                =           wgm1|wgm0,
31
32
      clearmask_ccb                = wgm3|wgm2
33
34
35
  } //.TimerRegs
36
37
// enum class - bitmask operators
38
39
   template<> struct std::enable_bitmask_operators <Mcucpp::Timers::TimerRegs<3>::tmode>
40
   { static constexpr bool enable = true; };
