Knight Rider VHDL
Guest #6641456
Hello guys!
I am trying to do some sort of "Knight Rider" car with VHDL, using my
Artix Board. Right now I have learned how to shift a single bit from
left to right and vice versa. The issue is when I try to add the tail
and use the PWM technique to control the intensity of light from one led
to another. It all gets messed up when I use long tails. Anyone who has
experimented something similar before? I would be glad if anyone shared
any idea on how can we deal with such cases:).
Guest #6641503
If you write down how each light has to behave in every situation, maybe
you understand how is to  be implemented. First try without PWM, and the
add the PWM.
The moving of the light can be done with a folding counter, you count
from 0 to 7 with 3 bits and map 5 to 3, 6 to 2 and 7 to 1. A shift
register can also be used, you shift left and right you need 5 bits.
Fading of the light can be done afterwards, one more counter per light
that gets loaded when the light has to turn on.
write it down, it will make sense.
Guest #6641617
There is an example project for the MAX1000 board, which also creates
such a light. You can look at the code there.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
