SDRAM read problem
Guest #6630892
Hello guys, I'm working with the IS42S16400 model 64-Mbit SDRAM that I
have. I write 16-bit data to random addresses and read. It's okay to
write, but I'm having trouble on the reading side. I used the SDRAM
controller model in the link. The friend who designed it used
IS42S16160G. I changed the timing and address sizes according to my own
integration.
constant CL : integer := 2;
constant tRCD : integer := 2;
constant tRP : integer := 2;
constant tRAS : integer := 4;
constant tRC : integer := 7;
constant tREF : integer := 64;
In the test program I designed, I printed the values ​​I specified in
the addresses below and then had them read.
Address -> Value
1024    -> 3000 + state
2097152 -> 16000 + state
2048    -> 12000 + state
8192    -> 6800 + state
16384   -> 1800 + state
32768   -> 5862 + state
As seen in the picture true_read.PNG, the data I wrote was read
correctly.
However, if I change any address or address content and read, the
address content is read incorrectly.
I changed the address content of 2097152 to 19000. He read this address
Sometimes it reads incorrectly on the first load. Why is it reading
incorrectly this way?
SDRAM: https://bertantaskin.com/fpga-ile-sdr-sdram-kontrolu/
SDRAM Test:
https://github.com/onur94/FPGA/blob/master/SDRAM_Controller_Fifo.vhd
Guest #6632456
If I understand you correctly you have a problem with your simulation,
right?
With the simulator you can usually check the content of your RAM to see
if the problem on read or on write.
Duke
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
